![]() | Home > Maintenance & Mods (L322) > L322 (2005) sunroof help, please! |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
I haven't found my particular problem discussed on here, but I'm convinced there will be someone out there who is knowledgeable on the sunroof on the L322 and will be able to guide me ...
Hi, SteveyD, that’s really helpful, thanks. I knew there’d be someone on this wonderful forum! |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
No problem. Sounds a bit odd that one, the bezel is one piece and is bonded to the headlining so to access the actual bezel itself you need to drop the headlining, it's not a big job but a bit pointless is say. To drop the headlining you need to remove all pillar trims, interior light, grab handles and retainer hooks and the 15 screws in the sunroof. Doing that would let you drop it and see what's going on. Failing that, try removing all 15 screws and gently pulling it down by the sunroof void, to get the rear screws you might need to remove the sliding cover. To do that you need to remove both gators on the sides of the sunroof glass, then the 3 screws on each side, pop the glass out then pull the cover forward, then remove the 4 screws (outside) then slide the cover away.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35830 ![]() ![]() |
can you not use slightly bigger screws to compensate for the larger holes?. ... - .- -.
Longer or thicker screws may crack the plastic that they are screwing into, filling the holes with resin and using the original screws would be better. Trial and error I guess. |
OK, thanks all |
