Home > Maintenance & Mods (L322) > TLC on the seats
proser
TLC on the seats
When i purchased the FF I knew that the drivers seat needed some TLC and with good reviews I purchased Liquid Leather's Scuffmaster Kit.
Once I had cleaned the seat with the LL cleaner they looked even worse and the door handles even more so
I decided to water down a small amount as I felt that it would soak into the leather better and also be easier to apply/blend. After a couple of coats I could see a difference and became more confident in applying the dye.
I decided to use the neat stuff and with a small sponge just dabbed it on the worse areas and let it absorb/dry out and the stippled affect from dabbing disappears. A couple more coats and then one of the watered down solution to blend into the whole seat.
I did try and mask off the piping but nothing I had stuck that well. Found that a damp cloth removed the dye really easily before it had time to dry.
The front passenger seat had a few marks which covered over with a couple of coats, but did not need to blend across the whole seat - confidence growing with blending the dye in a small area Very Happy
the door handles needed 3 coats of neat dye and looked a lot better
Before
After
There were a few marks on the glove box and door cards and was able to cover them with the same dye. I even used some on the load space cover where it had got grubby, around the middle handle, and wouldn't clean up. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #341658 10th Aug 2015 2:50pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Looks fantastic
Post #341659 10th Aug 2015 2:59pm
Zirconblue
Funnily enough i've just done the same on mine. It's great stuff.
Post #341662 10th Aug 2015 3:18pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
We use Bradleys to the same effect
Looks Thumbs Up
Post #341663 10th Aug 2015 3:25pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Looks great mark. Well done. Very Happy
I'll have to try some on mine. Thumbs Up
Post #341665 10th Aug 2015 3:30pm
proser
Thanks Guys.
I am really impressed by the finish and the colour match, considering the colour it looks like in the bottle. also on all the other surfaces that it works with.
I still got an area that I want to sort out around the ignition. Got a semi circular black line where the top surface coating has been rubbed off.
May even offer a service to fellow members Thumbs Up Regards
Mark
2012 Westminster
Post #341666 10th Aug 2015 3:37pm
proser
@gregdav - just noticed your location. If you have ivory leather then feel free to try some of the dye I have. Regards
Mark
2012 Westminster
Post #341668 10th Aug 2015 3:39pm
gregdav
Thanks for the offer mark only just noticed your location.
Pity mines a sand interior, I have been looking at this for a while now. I've just showed the wife what you have been able to do, she's also very impressed. You've spurred me on to have a go myself.
Cheers. Greg. Thumbs Up
Post #341672 10th Aug 2015 3:49pm
proser
no problem. If you want any pointers when you come to do yours then shout Thumbs Up Regards
Mark
2012 Westminster
Post #341674 10th Aug 2015 3:51pm
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Nice result. Thumbs Up
I did a refurb on mine a while back (in the Wiki section) but have been thinking of touching up the handles/arm rests and this could be an easy solution.
Post #341677 10th Aug 2015 4:02pm
