Home > Maintenance & Mods (L322) > Had some damage due to road works, need advice
Page 2 of 4 <1234>
Suggs
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
detailer from the contractor is going to give me a date, told him im not waiting weeks and i threatend to take legal action againts them. so he said he will come one evening soon and let me know when tomorrow..
its a nightmare round here, i live in a very small rural village and they have pretty much attacked the few surrounding roads we have so it cant be avoided until the surface becomes sound. Its like driving on marbles.
watch this space...
Post #341934 11th Aug 2015 11:12pm
Zirconblue
Probably a good case for fitting rear mudflaps, the fronts obviously did their job.
Post #341942 12th Aug 2015 12:01am
+1 for the diesel route Thumbs Up Brake cleaner is another good product Thumbs Up
Use it to remove tar from tools Thumbs Up
Post #341943 12th Aug 2015 12:12am
Zirconblue
Only just seen the mention of diesel, that will definitely dissolve it!
Post #341950 12th Aug 2015 12:42am
Suggs
wont damage the paint or plastic inner arches though will it
Post #342123 12th Aug 2015 8:59pm
Zirconblue
Nope, but it will damage your skin if you don't wear rubber (PVC) gloves when you do it.
Plenty of cars have diesel leaks and the plastic doesn't fall apart or the paint fall off. Once you've got the tar off with Diesel, wash it down and put some fresh polish back on the paint, as the Diesel will likely strip off any wax polish that's on there.
I think you'd be best slapping in on there with a paint brush, as it'll be kinder on the paint than rubbing it with a cloth
Post #342124 12th Aug 2015 9:03pm
miggit
Think I'd get a small garden sprayer, you know the 99p things that you can also get WD40 in, and use that. You could probably wash most of it away using that method, I wouldn't recommend trying to rub it off as you'll probably spread it more, oh and put some news paper down to soak up the drips. Recon that a light mist and wait will soften it and a second squirt would shift it Thumbs Up
Scrub that, get the biggest sprayer that you can find and park on the road where it happened, apply large amounts of diesel to the problem areas and try not to laugh too much when doing Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #342130 12th Aug 2015 9:28pm
Zirconblue
http://www.amazon.co.uk/Babymoov-Ultra-Abs...rbant+pads
A pack of those will probably be better than newspaper. (and they're cheaper than the oil spilage pads)
Post #342133 12th Aug 2015 9:42pm
miggit
You lot not herd of kitty litter? way cheaper and just the same as the granules they sell for oil leaks. I still think that giving the tarmac back to the road builders is the best way Twisted Evil Yesterday I couldn't spell Engineer... Today I are one!
Post #342139 12th Aug 2015 9:58pm
Zirconblue
yep or sawdust also works well. But those absorbent pads will make the driveway a bit safer!
You might want to wear a mask too, diesel fumes smell awful, to the point you get the taste in your mouth for hours.
Post #342141 12th Aug 2015 10:03pm
Suggs
cheers
well hopefully they will sort it for me, otherwise ill have a go with the diesel
Post #342143 12th Aug 2015 10:07pm
miggit
Actually thinking about this the best way to save the driveway is to just put the kitty litter tray under the area to be cleaned and go for it, but remove Tiddles from the tray before you start, otherwise you will have a moggy with the right hump Shocked Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #342144 12th Aug 2015 10:10pm
Suggs
i dont have a cat, should i buy one then in order to get a litter tray so i can put it on the drive Smile
Post #342145 12th Aug 2015 10:11pm
Laughing Laughing Laughing Thumbs Up
Post #342150 12th Aug 2015 10:44pm
miggit
No, I wouldn't go that far, maybe you could knock on a neighbours door and ask to borrow theirs' Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #342162 13th Aug 2015 12:09am
Page 2 of 4 <1234>
