![]() | Home > Technical (L322) > Drivers Memory Function ?? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Disconnecting the battery won't upset anything else apart from the clock... it's worth a try but don't hold your breath... see the procedure for battery disconnect in the WIKI Pete
| Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118
Cheers Pete, nothing ventured............ Semper in merda sumus, solum altum variat !!
| apole Member Since: 27 May 2015 Location: Berkshire Posts: 29
Dunno if this helps but thought mine wasn't working correctly.
If you have the door open and ignition off it will move to the memory position with one touch of the button, if the door is shut or you have the ignition on you have to press and hold the button... it's to stop a one shot move whilst driving... could be dangerous... |
Thanks,
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
Mark 2012 Westminster GONE - 2007 Java Black FF Vogue, with Ivory interior |
Nope, no luck with mine, its just given up |
It seems the ECU is inside the drivers seat switch pack.... plenty on ebay
| All times are GMT |
