Home > Technical (L322) > Drivers Memory Function ??
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
For some reason the memory function on my drivers seat isnt working properly and wont remember the settings i put in, so do you think disconnecting the battery would help or would this mess up any other settings on the car before i do it, it may be the switch, i dont know, just a case of going through things i suppose, any suggestionswould be helpful ?
Ian Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #342656 15th Aug 2015 12:05pm
Disconnecting the battery won't upset anything else apart from the clock... it's worth a try but don't hold your breath... see the procedure for battery disconnect in the WIKI Pete
-Click here for Thread-
Post #342657 15th Aug 2015 12:22pm
Ianmaney
Cheers Pete, nothing ventured............ Semper in merda sumus, solum altum variat !!
Post #342680 15th Aug 2015 6:32pm
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Dunno if this helps but thought mine wasn't working correctly.
Turns out if I just press the memory button it moves slightly, whereas if I press and hold it moves to the correct position.
Post #343575 21st Aug 2015 9:53am
If you have the door open and ignition off it will move to the memory position with one touch of the button, if the door is shut or you have the ignition on you have to press and hold the button... it's to stop a one shot move whilst driving... could be dangerous... Thumbs Up Pete
Post #343577 21st Aug 2015 9:58am
apole
Thanks,
Makes sense and good to know. Thumbs Up
Andy
Post #343578 21st Aug 2015 10:01am
proser
Thumbs Up now I know why Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #343581 21st Aug 2015 10:12am
Ianmaney
Nope, no luck with mine, its just given up Big Cry Semper in merda sumus, solum altum variat !!
Post #344003 23rd Aug 2015 7:15pm
It seems the ECU is inside the drivers seat switch pack.... plenty on ebay
I take it the seats move manually?? if not try fuse 20 and there is a relay for them as well in the front fuse box.... Pete
Post #344043 23rd Aug 2015 11:02pm
