Home > Technical (L322) > Smoke from under the bonnet
Blade74
Australia
Thanks for the explanation Zircoblue.
The only weird thing was I had driven for an hour and the car was at temperature.
Then I stopped 5 mins to fill up the car.
Then drove 1 min home and pulled up in front of my garage.
It was then when it happened.
The temperature was about 5 degrees Celsius.
Post #336698 9th Jul 2015 10:04pm
Discotigger
It's a quirk of the FBH, sometimes when you do a short run in cold weather the FBH will kick in to warm up the car and engine, but when you then stop the FBH carries on to burn off any remaining diesel in the heater. That's when you're most likely to get the smoke and smell. It usually comes from the FBH exhaust which is located under the front passenger side wheel arch (Left hand side of vehicle if you've got a Right hand drive motor).
It can be somewhat disconcerting at first, but you will get used to it. It can also cause amusement when other people see it and think your car is about to go up in flames!!
Post #336848 11th Jul 2015 9:59am
GraemeS
Australia
Spotted the front wheel smoke this morning from my newly-acquired 4.4 TDV8 after a short run with the temperature around 8 deg C. The Topix build info show park heater not fitted which I had previously interpreted as FBH not fitted, but apparently not so, just the park heater function not available. I wasn't aware of the distinction.
Can the FBH be disabled?
Post #342871 17th Aug 2015 2:01am
Zirconblue
Why would you want to disable it? It warms the engine up faster so your cabin heats faster and also gives you a small fuel saving as a result.
You should be able to activate the park heating function though, probably even add the remote control too.
Post #342877 17th Aug 2015 7:14am
GraemeS
Australia
Its never cold enough to warrant the embarrassment of the vehicle emitting smoke from around the engine in public. FBHs are not generally fitted to Oz vehicles so no-one knows the explanation and a well-meaning person may call the fire brigade thinking the vehicle is on fire.
Post #343022 17th Aug 2015 9:47pm
It will usually smoke only the first few times it fires up for the winter, and if it hasn't been used for a while. It won't/shouldn't smoke as a matter of course.
During the winter my Fbh on the disco fires every morning and never smokes. When I enabled the remote function on it I had the guys at the garage re initialise it and it filled the garage with smoke! Not smoked since! There is nothing that can't be fixed with a hammer😜😜
Post #343023 17th Aug 2015 9:57pm
CEEGEE
The FBH can be pretty embarrassing - it strikes me as the most ridiculous and archaic solution to the problem for such an expensive and supposedly advanced car Whistle
I have diesel "central heating" in my VW California camper - it neither smokes or smells or embarrasses me Thumbs Up
Post #343024 17th Aug 2015 9:57pm
Zirconblue
I'd say the same in the UK, they're fairly rare in passenger cars, and with those that do have them, i'd bet few of the owners even know they do. Really only common in scandinavian countries and eastern europe i would think. But i've never seen a news report of someone's car being mistakenly dowsed by the fire brigade in the UK, given all the Diesel range rovers have them, i'd expect to see plenty of news stories about it if it were the case. Laughing Unless random car fires are a big problem down your way i don' think i'd worry about it.
If you get the remote for it and activate it you'll also be able to make use of the remote vent function - gets fresh air circulating before you get in the car. Wink
Post #343035 18th Aug 2015 1:09am
I would hazard a guess that the diesel heater in your California is the same as that in the FF. Possibly a different model of Webasto, but fundamentally the same thing. There is nothing that can't be fixed with a hammer😜😜
Post #343044 18th Aug 2015 7:48am
^ I would say so Boat heaters , Truck heaters and car heaters all usually Webasto .No competition bar a few small time players . 2008 MY Supercharged
Post #343054 18th Aug 2015 8:45am
Zirconblue
Eberspacher are their main competitor. Cab heaters are normally either Webasto or Eberspacher, i wouldn't call Eberspacher small time though.
They are all basically the same technology and generally put out a puff of fumes when started from cold, the same as a car engine does. It's hardly ultra new technology, but i'm not sure what other tech they could use to provide parking heating - a small nuclear reactor perhaps? Laughing
Post #343081 18th Aug 2015 1:05pm
Total brain fade Embarassed Censored
I have been building and skippering boats nearly all my life and Eberspacher completely fell out of my head there , in fact I have even been doing some research on them because both the 5kw and 10kw central heaters on my dad's boat are giving trouble . 2008 MY Supercharged
Post #343216 19th Aug 2015 2:21am
