Home > Maintenance & Mods (L322) > A bit's fallen off
A bit's fallen off
Whilst doing my annual wheels off poke about underneath yesterday I found this bracket lying on the front underside panel on the offside. I think it's intended to support something about 75mm in diameter. Before I start dismantling can anyone confirm what it is. My suspicion is that it's intended to support a turbo hose. Can't be very important, the car runs fine without it.
Car's a TD6.
Thanks,
Post #343245 19th Aug 2015 10:45am
That supports the whoopy cam flange foo-foo valve, if you start your car without it the car will self destruct..... Pete
-Click here for Thread-
Post #343279 19th Aug 2015 1:49pm
Seriously, I'd check it doesn't prevent a pipe from going too near a moving pulley, belt or the fan... Thumbs Up Thumbs Up Pete
Post #343280 19th Aug 2015 1:51pm
Weegie
I thought it was a bit of the house guttering. Very Happy
I have had a look at my engine bay and, without stripping it out, I can't see anything obvious. Also had a search through RAVE but again nothing obvious. John
GAP iiD BT-Sold
Post #343282 19th Aug 2015 2:24pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
That's one for international rescue David, I'd wait for Craig if he's not too drunk on holiday!
Post #343285 19th Aug 2015 2:29pm
Lost for Words
Think I've spotted it:
Looks like 19D624B? Question
The strange thing is, it lists it as PMU000130 "BRACKET, FOR INTERCOOLER HOSE, SUPPORT BRACKET" but a search for the PN reveals listings for "Bracket - Child Seat Mounting". Confused If that is it, then it looks Censored expensive at over £50 + VAT! Shocked Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #343292 19th Aug 2015 3:07pm
Cheers for that LFW Thumbs Up Definitely 19D624B.
Thank god for that I thought I might have to replace the whoopy cam flange foo-foo valve support bracket which I understand is only available from selected Main Dealers in Nairobi on Halloween. I've already had an email from such a Main Dealer offering the part and wanting my bank details and the dogs passports.
Out of interest, it does seem to have failed due to vibration as the bracket has fractured across the mounting bolt hole which is surprising as the metal is quite substantial.
Might be worth others having a look as I fear I can't be the only one.
Front underside panel off it is then. Thumbs Up
I'll check the roof guttering while I'm at it just to be sure. Wink
Post #343298 19th Aug 2015 3:27pm
