Home > Technical (L322) > Sloshing Water Sound Behind Dash???
Page 2 of 3 <123>
nice result...even if the water does leak back in , at least it can now drain out and give you peaceful motoring... ... - .- -.
Post #34324 29th Oct 2010 7:31pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Superb result............I will attempt mine but can’t tell from your picture exactly where you drilled, did you have to remove anything to get a drill in as I have the battery on the passenger side the air intake in the middle and the wiper mechanism on the driver’s side and don’t seem to have the space your picture shows............
Post #34353 29th Oct 2010 11:52pm
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
I'll take some more pictures to show the location and what needs removing. L322 2002 4.4 V8 LPG
Post #34373 30th Oct 2010 9:28am
netsonic Steve
Hi John , well took the decision to remove the air intake box which was more simple than expected ...........this gave plenty of room to get a drill in to drill the holes, ........i did two one either side and out poured the water ...great result. I also took the opportunity to clean in and around the air intake box which is just a bit of OCD kicking in according to the wife but made me happy........I can’t thank you enough for pursuing this issue which has become a most gratifying fix and for me at no cost as i did all the work myself today.
After putting it all back together i took the Rangy for a drive along a route that had plenty of hills, mini roundabouts and bends so within minutes the Rangy was as quiet as could be no water noise at all.
When i drilled the holes each side i also drilled them out to 10mm so water can drain with ease which has worked a treat
Many thanks again
All the best Steve
Post #34431 30th Oct 2010 8:33pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Shocked Thats not the Wiper housing.. thats the coolant chamber for the flux capacitor. If its splooshing it need to be topped up! Shocked
Wink 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #34446 30th Oct 2010 9:59pm
Ozzy Rangie
Australia 2002 Range Rover Vogue 4.4 V8 Java Black
Thanks for attaching old thread, sounds like thats it.
any chance of sending photo's to help identify where to drill?
Thanks for your help.
Chris
Post #309844 2nd Feb 2015 12:15am
Ozzy Rangie
Hello CyberMrT
I am having the same problem you had some time ago with the sound of sloshing water behind the dash.
I have read the thread but can't access the photo you posted, do you still have any photos showing where to drill the holes to release the trapped water?
Thanks
Post #309870 2nd Feb 2015 5:48am
Ozzy Rangie
HELP
The sound of that water sloshing about is driving me mad!!
Anybody know where to drill the holes? have taken air box out but can't see any obvious chamber that is retaining the water.
Post #310424 4th Feb 2015 2:37am
Andy.b
2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Sloshing water sound behind dash
I have been going over this thread again trying to find the picture of where to drill the holes to drain the water , but with no luck can anyone point me in the right direction? Also this is my first time so I am not sure if I have done this correctly
Post #534543 17th Nov 2019 11:50am
Andy.b
Water sloshing
For Ozzie Rangie did you find out where to drill the holes?
Post #535313 24th Nov 2019 11:47am
Andy.b
Anyone on where to drill these holes?
Post #535315 24th Nov 2019 11:48am
Philsarn
Wales 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi guys there is no photos now but this chap put this below so i will try it asap.
Hi John , well took the decision to remove the air intake box which was more simple than expected ...........this gave plenty of room to get a drill in to drill the holes, ........i did two one either side and out poured the water ...great result. I also took the opportunity to clean in and around the air intake box which is just a bit of OCD kicking in according to the wife but made me happy........I can�t thank you enough for pursuing this issue which has become a most gratifying fix and for me at no cost as i did all the work myself today.
Many thanks again
All the best Steve
Post #544640 20th Feb 2020 11:58pm
Philsarn
Water sloshing
Hi all having read all of the above I took the large centre air box out and drilled two holes each side of the vent inlets but no water came out. I must have drilled in the wrong place. I want to do this before I sell her. Please can someone help? Thank you!
Post #545822 2nd Mar 2020 9:26pm
robanzac
New Zealand
Hello Philsarn, or indeed anyone,
I now have the same problem.
I have read through all the thread but I can't work out from the descriptions where the successful people have drilled their holes.
I have had that centre heater air intake box out (with the pollen filter), but am still none the wiser. Rob
Post #623699 14th Feb 2022 7:38pm
robanzac
New Zealand
I think I have fixed the problem.
In the photo's you can see a 6mm hole I have drilled to the right of the loom earth stud.
No water came out when I drilled it (I have only ever had very mild sloshing so I don't think there has been much water in there), but after driving around there is evidence that water has drained out of that hole.
And no more sloshing since.
1st photo with heater air intake removed
2nd photo with heater air intake in place
 Rob
Post #625291 4th Mar 2022 5:36am
Page 2 of 3 <123>
