![]() | Home > Maintenance & Mods (L322) > Fire Extinguisher |
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 ![]() ![]() ![]() |
I'm about to fit a fire extinguisher just below the front passenger seat. Before I start drilling and screwing in self tappers, has any one here already fitted one? Any tips before I drill/screw through something I shouldn't.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
make sure you can still move the seat forward/back.. ... - .- -.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
I've just fitted an extinguisher to the factory mounts under the passenger seat.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You can fit the BMW X5 kit, it's about £75 for the extinguisher and the mounts (half the price of the LR one) The seat under frames are the same as the BMW X5.
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Hello, do you have pictures of the X5 parts installed? Thanks |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 190 ![]() ![]() ![]() |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
ive used a small 1kg extinguisher, and you only get about 8 seconds, and its empty... so I chose a 2kg one, and fitted it on the rear parcel shelf side panel. I can climb over, from the drivers seat, just, if car is in park, and grab it quickly, or from rear opened door etc. its on a clip mount etc. it only cost £15 too. better to have plenty... than to run out! its very visible too, in case, im not in position to operate it etc.
Thank you, but this is not from X5? |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 ![]() ![]() ![]() |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
That looks really nice & neat. Where can you purchase them from?. |
I got one form demon tweeks, search for fire stick, 30 seconds one was around £40 & arrived with its own plastic bracket too. |
