Home > Maintenance & Mods (L322) > range rover stuck in park 2003 model
wigmore321
United Kingdom 2003 Range Rover HSE Td6 Java Black
Hi
My range rover is stuck in park . i have checked brake lights they are fine
please help
Post #343899 23rd Aug 2015 10:49am
Its either physical or electrical:
1. Check the linkage from the gear lever to the gearbox under the car, and make sure this isn't seized (see wiki)
2. Presume the car starts up OK?
3. You can lift the gear lever gaiter and manually activate the lever lock to release "Park"
4. Problem exists between key barrel and gear lever electrics
Lots on here about all of these .
Post #343901 23rd Aug 2015 11:01am
