![]() | Home > Technical (L322) > Engine management fault |
I think the first thing is getting error codes read and see if there is anything that you can do with that. MY 2010 5.0 SC Galway green and sand interior!!
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
The famous split hose maybe? |
Bungal Member Since: 27 Dec 2013 Location: Hartley Posts: 44 ![]() ![]() ![]() |
I will plug in my IID when the wife gets home and grab some codes.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Top turbo hose, is a good place to start. See the wiki for how to repair/replace. It's super easy.
I got a list of errors
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Use google, I'm sure they will come up with some answers 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
look at the info here for codes P0101 & P023D - http://www.rrsport.co.uk/forum/topic34009.html . The other codes are probably as a result.
Brian, it will takes you 5 minutes to check the hoses.
I have just checked the hoses.
That's where they go!
Cheers guys
Yes I would think so as you have less air going past one maf.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Does wrapping the split hose in gaffer tape work? (it's surprisingly strong!)
