Home > Technical (L322) > Engine management fault |
I think the first thing is getting error codes read and see if there is anything that you can do with that. MY 2010 5.0 SC Galway green and sand interior!!
24th Aug 2015 9:21am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
The famous split hose maybe? |
24th Aug 2015 9:32am |
Bungal Member Since: 27 Dec 2013 Location: Hartley Posts: 44 |
I will plug in my IID when the wife gets home and grab some codes.
24th Aug 2015 6:03pm |
Top turbo hose, is a good place to start. See the wiki for how to repair/replace. It's super easy.
24th Aug 2015 6:18pm |
I got a list of errors
24th Aug 2015 10:05pm |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 |
Use google, I'm sure they will come up with some answers 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
25th Aug 2015 9:50am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
look at the info here for codes P0101 & P023D - http://www.rrsport.co.uk/forum/topic34009.html . The other codes are probably as a result.
25th Aug 2015 10:07am |
Brian, it will takes you 5 minutes to check the hoses.
25th Aug 2015 11:50am |
I have just checked the hoses.
25th Aug 2015 7:00pm |
That's where they go!
25th Aug 2015 7:02pm |
Cheers guys
25th Aug 2015 7:06pm |
Yes I would think so as you have less air going past one maf.
25th Aug 2015 7:43pm |
25th Aug 2015 7:55pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Does wrapping the split hose in gaffer tape work? (it's surprisingly strong!)
25th Aug 2015 8:04pm |
