Home > Maintenance & Mods (L322) > What does the TD6 oil filter look like
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Have bought bits toget the TD6 oil Change done and the filter is a quite short, paper type filter, is this right guys? Never seen one before but was expecting it to be metal, like on most of my previous cars
Yours, slightly confused...
Post #344429 25th Aug 2015 9:18pm
Sounds right to me.
It is a paper element about the size of a Campbells (now Baxters!) condensed soup tin.
In the engine bay to the right of the engine near the front you will see a black dome with a a big nut on top (36mm)
After draining the oil, place a large rag underneath, then undo this to remove the old filter. Don't forget to change the rubber O ring and rung a sliver of grease around the sealing flange when putting back together for a good seal. .
Post #344431 25th Aug 2015 9:26pm
