![]() | Home > Maintenance & Mods (L322) > Underseal |
Hi mate, welcome to the nut house. Cam Tech Craig may be able to help, I seem to remember that he does a fair bit of anti-rust treatment on his own FFRRs and I assume also for clients. He may be able to help you with this I hope. MY 2010 5.0 SC Galway green and sand interior!!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
They're already under sealed from the factory, actually the majority of mass produced cars from the early 90's on have it.
crankcase Member Since: 07 Aug 2015 Location: lancashire Posts: 10 ![]() ![]() ![]() |
Thank you gents
Thanks Zircon ...
Some drive on ramps and axle stands would do.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
If you are on a tight time table / access problems - I suggest doing the following most urgently
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
The FF is far better built than the earlier Range Rovers (admittedly nowhere near as good as some German stuff though) because it is a monocoque it is made of much thicker metal as well...
Thanks Smutt
Hi - no problem - sorry for the short info on this I gave.
mjdronfield has some nice pics here for you
Haylands, Smutt and all
Strip out was from when it went swimming and couldn't hold it's breath... It was just to show how good a condition the floor was in after 13 years...
