Home > Technical (L322) > Tilting Mirror
g1968g
Tilting Mirror
Hi,
If I remember correctly, on my 06 TDV8, when I selected reverse, the mirror moved in and down.
On my 2010 SC id moves in and up..
Or am I going mad.
Cheers
Geoff Looking for FFRR
Post #345147 30th Aug 2015 6:14pm
If you make it move by selecting reverse with the mirror switch in the correct position, then adjust it, it will do what you want... well that's how the earlier ones work so I guess yours is the same... Pete
Post #345149 30th Aug 2015 6:19pm
Zirconblue
I think it has two memory positions, normal and parking. So put it in reverse and wait for it to tilt in and up, then adjust to where you want it. When you deselect reverse it should go to the normal position and when you reselect reverse it should remember where you had set it to.
Post #345152 30th Aug 2015 6:40pm
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
Dear Geoff,
On your old TDV8 Laughing you have to flick the switch that changes whether you are adjusting the left or right hand mirror. If you flick it to the left hand mirror then when you select reverse the left mirror drops for the kerb.
The car is doing great by the way. The paint work is not quite as prestige as when you sold it to me as it has now seen a lot of off-road action at various SLROC and Comp Safari Events. It is perfect for what I wanted it for though. Just spent two days Setting up and Clerk of Course-ing at the most recent CCV at Kidlaw near Haddington, so approx 300 miles of road driving and all over the bestest, bumpiest, farm land in Scotland and it was superb.
I hope Abu Dhabi is being good for you and you are not missing "Sunny" Scotland too much Whistle
All the best 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #345159 30th Aug 2015 8:07pm
That's what I said...!!!!! Pete
Post #345198 30th Aug 2015 11:50pm
Geoff, all of the above relates to PRE 2009 cars! The reverse mirrors are settable from the dash display on 2009my> and is speed sensitive... The faster you reverse the further back to normal they go Thumbs Up
Post #345201 30th Aug 2015 11:57pm
Blimey... what can't they do....!!! Pete
Post #345205 31st Aug 2015 1:30am
Steveo
I have a 2004 vogue can any one tell me how to set the reverse dip mirror and if it is possible on this model thanks
Post #345231 31st Aug 2015 9:33am
from the owners manual Steve,
Post #345235 31st Aug 2015 9:44am
Steveo
Cheers is the dip mirror possision pre set or can it be adjusted
Post #345240 31st Aug 2015 9:56am
i think it can be adjusted whilst in the dip mode.. ... - .- -.
Post #345304 31st Aug 2015 2:35pm
g1968g
Had a look this morning.
Flick the switch to either side whilst in reverse to set the required position
cheers
Post #345420 1st Sep 2015 4:37am
Post #345447 1st Sep 2015 10:57am
Laughing There are lots of differences Pete... Whistle
Post #345448 1st Sep 2015 10:58am
Zirconblue
50mpg Laughing
Post #345515 1st Sep 2015 5:22pm
