![]() | Home > Technical (L322) > Tilting Mirror |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8770 ![]() ![]() ![]() |
If you make it move by selecting reverse with the mirror switch in the correct position, then adjust it, it will do what you want... well that's how the earlier ones work so I guess yours is the same... Pete
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I think it has two memory positions, normal and parking. So put it in reverse and wait for it to tilt in and up, then adjust to where you want it. When you deselect reverse it should go to the normal position and when you reselect reverse it should remember where you had set it to. |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Dear Geoff,
That's what I said...!!!!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
Geoff, all of the above relates to PRE 2009 cars! The reverse mirrors are settable from the dash display on 2009my> and is speed sensitive... The faster you reverse the further back to normal they go |
Blimey... what can't they do....!!! Pete
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
I have a 2004 vogue can any one tell me how to set the reverse dip mirror and if it is possible on this model thanks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
from the owners manual Steve,
Cheers is the dip mirror possision pre set or can it be adjusted |
i think it can be adjusted whilst in the dip mode.. ... - .- -.
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 ![]() |
Had a look this morning.
50mpg ![]() |
