![]() | Home > Technical (L322) > What's this do? (picture inside) |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 ![]() ![]() |
thats just the water down pipe for the wiper arm area, it should just put the water down to the ground under the vehicle |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
............from the plug you can see top right in your pic.... I'd move it off the battery tray when you put it back....
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 ![]() ![]() ![]() |
It's pretty obvious what it does |
Sorry, I was just answering the thread title.
That's fine, I appreciate your reply mjdronfield, thank you. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Fuel burning heater is standard on Diesels.
Thanks, that's what I did (looked at the other side) but the hose there is longer than this and appears connected/fastened at both ends. I'll leave it like that since it didn't cause any visible issues until now. |
