Home > Technical (L322) > NEW OWNER GETTING TO GRIPS WITH 2003 V8!!
Alex Millar
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Bought a 2003 v8 4.4l in June and drove it 400 miles from London to Glasgow. Although the previous owner was an enthusiast and had a fulfat sticker on the rear window 4 weeks later I got the car back from my mechanic with a new gearbox,rear suspension,rear brakes,bushes and a full service Crying or Very sad
I now have a list of rust proofing and mirror fixing jobs to do which fullfat have been great at explaining how to do but I now have a more serious problem to attend to which needs your help and advice. I am having times when reverse gear is not engaging. It is intermittent, mostly from park to reverse than from neutral to reverse and also now noticed the offside mirror moves downwards on reverse selection and back to it's position when I come out of reverse. It can happen from start up or hot, flat or incline and I am not confident on making a journey in the car now.
Please can you suggest what is going wrong.
Post #347278 11th Sep 2015 8:49pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Alex , i would go straight back to the garage that fitted the new gearbox as a first, the mirror thing well the nearside should dip in reverse so only an anomoly, apart from that sounds OK Thumbs Up
Post #347279 11th Sep 2015 8:53pm
As Rosco says, mirror is normal behaviour, if you don't want it to do it then move the mirror switch to the nearside position..
Gearbox could be loose selector on the side of the gearbox.... Pete
Post #347280 11th Sep 2015 8:59pm
Alex Millar
Thanks guys Bow down .The car has still to get the prinns LPG vaporiser replaced as it had been silicone repaired which was not safe and I'll ask them to check this then.
Just to be sure is it correct that the nearside mirror is meant to move downwards in reverse?
Post #347298 11th Sep 2015 9:47pm
Rosco
Bloody LPG, Thumbs Up Pete is your man for that and yes nearside mirror moves to help your wife park Rolling with laughter
Post #347300 11th Sep 2015 9:51pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Yes,
There is a small switch on the drivers door (in front of the window switches), in one position it disables the mirror from moving downwards.
Post #347301 11th Sep 2015 9:53pm
Alex Millar
Thanks for that - I'll switch that button tomorrow.Struggling to get the wife to drive this car as it's auto! She still prefers her Subaru Impeza Sti.
Post #347302 11th Sep 2015 10:06pm
Rosco
Well Alex we all have crosses to bear Thumbs Up hopefully not a major issue. loads of help on this forum Thumbs Up
Post #347305 11th Sep 2015 10:13pm
