![]() | Home > Technical (L322) > Dead key fob after 3 mths without use |
Go down to Dan -UK's post for the how to , it sound like the key is out of sync .
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Thanks for the reply. I couldn't get the key to unluck or lock the car. ______________________________
So did you re-sync the key then ? 2008 MY Supercharged
Yes, I followed Dan's procedure as follows:
As long as you don't make the mistake of turning the ignition off between keys you are doing everything right , try a battery reset and persevere a few more times . I had the same problem and took it to the stealers to be told I needed new keys , $1700 here unlike the 170 GBP everyone else pays so I took it home and tried again with the re-sync which worked this time .
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2733 ![]() ![]() |
For your phone if its still not working properly, try pairing a different phone then try your one again. Even my MY12 fussed when first pairing my phone, but fixed after pairing the dealer's phone then mine again.
I gave the key procedure another crack without success. I've given it back to the mechanic this morning. He will autologic it without charge to sync the keys. Thanks anyway.
