![]() | Home > Technical (L322) > Question re park heat |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Shouldn't be too difficult to get the parts from a scrap car, will certainly be much cheaper. All the TD6's had them as standard.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8770 ![]() ![]() ![]() |
As above it will already be fitted all diesel range rovers had them as standard afaik, on a VSE I would think it should also have a remote with it! Probably got lost. Are you sure that it's not on the main screen? There is nothing that can't be fixed with a hammer😜😜
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Thanks so much for the prompt answers. I've checked the screen and followed the owners manual and it's certainly not where the booklet says it will be I thought it would be standard on this model.
if its an Irish spec car it varies slightly from the UK.
FYI the guide me home lights would need to be setup at the same time as the park heat function as they are enabled through a diagnostic tool and the delay is set as well. I also enabled mine to have the Scandinavian light setup so that my lights are always on during the daytime. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
If the receiver isn't already fitted in the boot, you should be able to activate park heating without it. That'll give you the ability to set it through the touch screen to come on at a given time. |
Thanks all. I think buying the IID tool seems to be my first step. 2015 4.4 AB
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
I got a petrol 4.4 2003 with the webasto heater and my question is: on the main screen i can select "aux heat/ventilation". Does this mean i can only heat up my engine and not the cabin? Thought i read somewhere that it have to say "park heat" to warm the cabin up.
Mine is a slightly later one with the touch screen. And has a menu for "Timed Climate".
Thanks for the replies gents I'm looking on eBay for the IIB Tool Price is about 280 stg. Does that seem ok ? 2015 4.4 AB
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Just an FYO but i believe with IID once you enable the park heat function you also need to reset the dash (also with IID) so that the changes take effect.
Yeah, there is an option in both the climate control system and instrument cluster to enable it. |
Thanks for the input. I'll have it next week and I'm away for weeks hols and then I be asking slot more questions no doubt 2015 4.4 AB
Hi all. I got the Iid tool and set FBH to on. Haven't tried it yet as battery was flat after playing with tool. One question , FBH MODE mine is in KBUS and I had the option to change it to normal. When I tried it would not amend CC files. Any thoughts ? 2015 4.4 AB
