![]() | Home > Technical (L322) > ff gave me a heart stopping time |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668
Ahh, the Death Bong, don't you just love it, NOT |
| saucyboar5 Member Since: 08 Sep 2015 Location: Staffordshire Posts: 20
Here's what is happening now on the on board diagnosis at 3.000 rpm in park..look at the battery volts.. |
Me thinks your alternator is fubar'd |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Yep that looks goosed. If you are v decent with the spanners then it's do-able, if not then it's a general garage job. There is nothing that can't be fixed with a hammer😜😜
Had the AA out...battery ok...charging on his meter 13.5 v
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
I take it you've double checked the battery terminals? I had a very similar incident when the negative terminal was loose.
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
13.5 volts is not good?????
13.5 volts is the minimum that the battery will charge, but the on board says it's 12.5 volts which is no good to man or beast. It could just an issue with the voltage regulator, and changing the brush pack will sort it, or it could be a lot worse and some of the windings have failed.
This may help you, http://www.rrsport.co.uk/forum/post269863.html
Do not get it repaired!!! It's a bas |
Well its going to hospital on Saturday |
