![]() | Home > Technical (L322) > V8 head gasket failure? |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215
Ok, a few days ago I had a "coolant low" alarm, I had been cruising quiet happily at 90km/hr. Engine running sweet, coolant had been checked that day, have had no leaks and no abnormal running or any other indications of a problem.
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
The RR cooling system is a pressurised system. The only time there would be no pressure in the system is when the engine is cold. The system is pressurised to stop the coolant boiling when in normal use.
Hi Andy yes correct, I accept your comments as true.
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
Thought all RR's used pink/orange coolant? |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Yes wrong coolant for a start , although it is possible the system was completely flushed before the wrong coolant was put in . 2008 MY Supercharged
| BIGMAMMA Member Since: 28 Oct 2012 Location: LEICESTERSHIRE Posts: 176
I have a BMW engine V8, 2004, but had a similar incident in February this year; Ironically checked the water level only that morning and topped up a little. Minding my own business, actually on my way to taxi Mother Dear to airport for her Winter hols. Didn't get there. The first inkling I had was when the following car (only doing around 30mph) backed right off and I saw what I thought was smoke following me. Stopped within 400 metres to find water everywhere in the engine bay. Called Mr RAC man who promptly arrived to establish header tank had a split on the corner from top to bottom. He attempted to 'plastic repair' the split and then refilled with water. She was a cow to restart - apparently typical if the head gasket's gone, and she boiled again very quickly. Diagnosis confirmed, and then left me, having arranged for proper recovery of stricken FF.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
dont panic just yet. The coolant system is a |
Thanks for all the replies.
| vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390
similar issues with my car |
Im no expert on these L322......yet.
Well almost two years since my original post and all is still well with the FF.
