![]() | Home > Maintenance & Mods (L322) > Spark Plugs Stiff and Difficult to undo - SOLVED |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459
No 6 plug is very very stiff but started to undo a fraction of a turn.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Good luck!
| Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 509
If in the very unlikely event that you have stripped the cylinder head thread all is not lost.
Thank you Gentlemen for your time ...
| Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223
try putting the rest of the plugs back in and running the engine up to temperature and and then taking the plug it usually frees them up on most engines L322 2008 vogue
Thanks Ivor. I had warmed up previous cars but due to conflicting Internet info I found suggestions that the bmw alloy was better left cold.
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
Hi SMUTT haven't tried it myself, but some people I heard of have used coca cola, soak overnight, mechanic did it on my sons audi when he couldn't get the injectors out. It worked.
I use the cup of tea method when removing the bottom off of skyline engines apply pressure have tea come back apply more pressure have tea and repeat until it comes off ,theres also a spray called shock and unlock it's basically a freezing spray same principle as heat except reversed L322 2008 vogue
@gregdav - thank you - I had heard stories of people getting old engines that had sat rusting, to work using coke to free them - basically removed spark plugs and poured coke in the cylinders - left for a while, and it freed them up.
@Ivor - thanks for your input. I have a theory similar to that that the tiny twisting movement you induce needs time to work its way through the whole fixing. By applying too much movement in one go leads to - well hell sometimes! Howard
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
50/50mix of diesel and ATF is an excellent releasing agent |
@47p2 - thanks for the input.
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
well done that man.... |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Well done Howard, glad you got that out OK... |
