![]() | Home > Technical (L322) > Headlight height adjustment stuck! |
Pazuzu Member Since: 02 Mar 2009 Location: Ashford, Kent Posts: 40 ![]() ![]() |
Hi chaps,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
if you haven't already try downloading the RAVE L322 workshop manual. This should detail how to dismantle the headlight and adjuster.
Got the manual and it shows exploded diagrams of the parts but no 'how to' in terms of removing them unfortunately.
TRY THIS - GOT IT FROM ANOTHER SITE
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
to remove the headlamp you remove the grill be carefull as the temp sensor is atached to it , remove the 2 top bolts and the 1 on the inside edge hidden by the grille , remove the big plug at the rear and gently wriggle out it worked for me |
Aha, I'd removed the grill but hadn't seen the extra bolt. I'll have another go in a minute. Cheers! Phil ![]() |
