Home > Wheels & Tyres > 22in wheels tyre pressures
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I have just bought a 2009 vogue se which is fitted with 22in wheels ,does anyone know what the tyre pressures should be with this size tyre 285/35 R22 106Y.From what I have read 22in wheels are not really the way to go but as they are in very good condition with nearly new tyres I,ll stick with them for now.Any help would be appreciated. 2009 Vogue SE Zermatt silver
Post #349933 29th Sep 2015 2:45pm
mod edit, moved to the correct section ... - .- -.
Post #349935 29th Sep 2015 2:46pm
mrtidy
sorry put it in the wrong section..thanks stan,fullfatrr sticker on rear window now too . 2009 Vogue SE Zermatt silver
Post #349938 29th Sep 2015 2:51pm
i'll let you off then Laughing Thumbs Up ... - .- -.
Post #349940 29th Sep 2015 2:55pm
miggit
I can't help you with exact pressures as I don't run those tyres, but from what I can suss most people with rubber bands tend to run them at higher pressure than standard, so 33 psi would be a good starting point Thumbs Up
I can tell you that I run mine on 33 front and 45 rear (18's) but that is because I do a lot of towing. The main thing is to put enough air in the tyres so that they look inflated, but not too much so that they are perfectly round, as you'll get a really bad ride and no grip in the wet Shocked If you look on the side of the tyre there will be will be in small and impossible to read print, a maximum cold pressure, do not exceed this. And I'd try and stay 10-15 psi below that Thumbs Up
The higher the pressure the better fuel economy you'll get, but at the expense of ride quality and grip. Yesterday I couldn't spell Engineer... Today I are one!
Post #349977 29th Sep 2015 7:04pm
mrtidy
Thanks for you're help Martin. .I'll use your figures as a starting point and see how I get on..Thanks again. . 2009 Vogue SE Zermatt silver
Post #350027 30th Sep 2015 12:38am
martin? ... - .- -.
Post #350040 30th Sep 2015 8:25am
miggit
Shocked Question
Wasn't Me Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #350042 30th Sep 2015 9:10am
mrtidy
Rolling with laughter don't know where i got the name Martin from. .. 2009 Vogue SE Zermatt silver
Post #350047 30th Sep 2015 10:02am
It's easy to determine the correct tyre pressure for any size tyre...
1. Make your best guess.
2. Ensure the tyre is cold, overnight is best.
3. Pump up to your guess.
4. Drive at 70mph for 20mins minimum (i.e. get the tyre up to normal temp)
5. Stop and check the tyre pressure. It should be exactly 4PSI higher than step 1.
6. If it isn't then adjust the starting pressure until you get it right...
Thumbs Up Thumbs Up Pete
Post #350048 30th Sep 2015 10:16am
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Re: 22in wheels tyre pressures
I have 40 all round in mine 285 x 35 x 22, nice even wear all round
Post #350867 6th Oct 2015 1:30pm
mrtidy
Thanks for all the replies guys ..I,ll see how things go..very helpful . 2009 Vogue SE Zermatt silver
Post #350872 6th Oct 2015 2:02pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have those tyres on my 06 SC and run the pressures as per the label on the door pillar. I run at the lower pressures (sub 100mph unloaded) as that's how I drive and this seems fine. For a while I tried the higher over-100mph pressures and the ride over bumps was noticeably worse.
Post #351511 10th Oct 2015 12:42pm
Can any member with a 405 running on factory 22’s give some insight as to what they run their’s at?
Post #351533 10th Oct 2015 1:37pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
My 2016 tyre pressures from factory are
Light load 34front 37 rear
Heavy load 40 front 47 rear
Hope this helps. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #351561 10th Oct 2015 5:31pm
