![]() | Home > Wheels & Tyres > 22in wheels tyre pressures |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
mod edit, moved to the correct section ... - .- -.
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
sorry put it in the wrong section..thanks stan,fullfatrr sticker on rear window now too . 2009 Vogue SE Zermatt silver |
i'll let you off then |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I can't help you with exact pressures as I don't run those tyres, but from what I can suss most people with rubber bands tend to run them at higher pressure than standard, so 33 psi would be a good starting point |
Thanks for you're help Martin. .I'll use your figures as a starting point and see how I get on..Thanks again. . 2009 Vogue SE Zermatt silver |
martin? ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8754 ![]() ![]() ![]() |
It's easy to determine the correct tyre pressure for any size tyre...
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
I have 40 all round in mine 285 x 35 x 22, nice even wear all round |
Thanks for all the replies guys ..I,ll see how things go..very helpful . 2009 Vogue SE Zermatt silver |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I have those tyres on my 06 SC and run the pressures as per the label on the door pillar. I run at the lower pressures (sub 100mph unloaded) as that's how I drive and this seems fine. For a while I tried the higher over-100mph pressures and the ride over bumps was noticeably worse. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Can any member with a 405 running on factory 22’s give some insight as to what they run their’s at? |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
My 2016 tyre pressures from factory are
