Home > Technical (L322) > Genuine BMW PCV valve or one from eBay (from China)
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi guys, looking to get the Rangie back on the road.
Just bought replacement silicone hoses from creation Motorsport and looking to get a new PCV and have read on here that the BMW part number 11617508541 is around half the price of the Land Rover one but I'm unable to locate a genuine one. I've found a few on eBay for cheap but from China, guessing though that even genuine ones are made in China anyway but unsure of quality.
I have googled the BMW part number but not coming up with much, tried other searches too with no luck. 2004 RR 4.4 V8 Autobiography
Post #350058 30th Sep 2015 10:20am
Zirconblue
Can't a BMW dealer get you one?
Post #350066 30th Sep 2015 10:57am
Martin
Site Admin
LKR000040 Genuine LR about £75+VAT after discount, try Dan @ Duckworth: duckworthparts
11617508541 Genuine BMW about £65+VAT
Post #350081 30th Sep 2015 12:21pm
johnboyairey
ive got one i bought to fit when i do my valley pan gasket, however, i youtub-ed it, and found i could buy just the soft rubber part, (the bit that fails) and save myself a lot of grief, (ie not getting the bolts out), by just unclipping it, and snapping the new one into place, -no bolts etc. and just abound £20 if i remember. -off ebay.
Post #350096 30th Sep 2015 2:12pm
PaulM
I'm guessing there's not much to this part, so a cheap one off eBay wouldn't be make any difference? 2004 RR 4.4 V8 Autobiography
Post #350144 1st Oct 2015 12:33am
PaulM
I didn't want to take a chance on a cheap part so bought one from BMW dealer. I'm going to make a coffee and start work on the PCV valve time to get it back on the road after sitting on the drive for 6 months. 2004 RR 4.4 V8 Autobiography
Post #360485 5th Dec 2015 8:52am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@PaulM - there are 2 great posts in the Wiki - and supplementary info on useful tools and bolt sizes in my post half way down this page.
http://www.fullfatrr.com/forum/topic34480.html?highlight=pcv
Good luck Thumbs Up Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #360490 5th Dec 2015 9:27am
Reecy
2003 Range Rover Vogue 4.4 V8 Santorini Black
Paul
Get yourself ready for a day that is a pain
I did my PCV pipes recently and the job tested my patience- it really did
So make sure you warn people off interruptions etc
However, whilst it's not the biggest job on a strange rover it is a fiddly one
Have fun
Reecy
Post #360717 6th Dec 2015 6:37pm
PaulM
Ok well it went well taking it off, came off in no time without any issues at all. Only problem I had was the wind blew away my gasket Big Cry It has also been bodged in the past with glue and had jubilee clips missing, pipes not connected etc.
I do have a few questions though wondering where the pipe on the top of the valve goes, you can see it attached still to the yellow part in the picture. Also the very bottom hose that I'm holding looks to be perished, the one that attached to the small pipe that often breaks off but didn't on mine, it also wasn't connected at the other end.
Post #360727 6th Dec 2015 7:07pm
SMUTT
@PaulM wrote "....very bottom hose that I'm holding looks to be perished, the one that attached to the small pipe that often breaks off but didn't on mine, it also wasn't connected at the other end. "
OK this one goes to a metal pipe which leads to the sump.
The pipe is situated alongside the pipe that connects to the Oil Separator bottom hose. They both lead down to the sump.
So looking from front of car, they are on LHS at rear of engine LH bank. A mirror on a stick and torch are your friend.
You can feel for them quite easily - and if you lube the end of your new rubber pipe with a bit of oil, it is not difficult to push it on to the metal pipe.. Best to work from the sump pipe end back to the PCV. Some people have simply looped the pipe round the outside of the rear engine heater connectionmanifold rather than trying to trace it back through between the engine block and heater connection manifold. Because I like to make my life difficult I did the latter.
@PaulM wrote "... where the pipe on the top of the valve goes, you can see it attached still to the yellow part in the picture"
Sorry can't remember - too dark now - it is a vacuum pipe - if yours was not connected to anything before I guess you had erratic idle due to leaking the vacuum. Could have been to a black cannister about 10cm long by 4cm diamter, with similar vacuum pipe coming off the other side of it. Have a look around - too dark for me now at the moment. Howard
Post #360761 6th Dec 2015 9:18pm
