Home > Technical (L322) > Help with dashboard warning message
Cryptic
2002 Range Rover Vogue 4.4 V8 Java Black
Hi,
needless to say, some of the pixels on my dash are out, making reading the messages a little interesting.
Is this one transmission overheat? Or something else?
If it is transmission overheat, it appeared after putting in drive & turning AC on after being parked all day (it was sunny today). Any suggestions as to what's going on?
Thanks
Post #350239 1st Oct 2015 8:13pm
mjdronfield
That appears to be what it looks like.
Have a look at the bottom of the radiator and see if it looks in good order. The bottom bit is used to cool the oil for the transmission. Get it swapped or flushed out if it looks bad.
This may help a bit, even if it's for a later car than yours ?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #350240 1st Oct 2015 8:34pm
Cryptic
Is it not a bit strange getting this after it was parked for 9 hours? (Started up, into drive, AC on and bing)
Rightoh - thanks. I'll check the rad & google the overheat message for more info.
Post #350242 1st Oct 2015 8:46pm
mjdronfield
Faulty sensor ?
Had that on my Discovery 2...... Nothing wrong with the box......
Is your gearbox actually going into the overheat mode like it says in the info above ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #350243 1st Oct 2015 8:48pm
Cryptic
I didn't notice anything driving it afterwards - and did more than usual evening run including motorway stretch - a couple of hours driving.
Having said that, I did think something didn't feel quite right in the last couple of miles before parking up for the night yesterday. This morning, everything felt fine - I chalked it up to my imagination.
Post #350248 1st Oct 2015 9:13pm
Cryptic
Today the warning came on at starting up. For first 10 mins driving, gear shifts were clunky and then smoothed out. Haven't checked the rad yet, but suspect it might all be a simple as a fluid and filter change.
Post #350356 2nd Oct 2015 6:58pm
If transmission oil cooler is clogged up, no amount of fluid and filter changes will make any difference. On a MY02 it is probably worth removing the cooler to see what is what. IIRC a new one is not all that expensive.... .
Post #350385 2nd Oct 2015 10:20pm
miggit
Shocked That display looks like mine Shocked That's why I got the Bluetooth IID tool, so that I could find out what it's trying to say, are you sure that it's not say transmission gone left Shocked
Re cooler, I picked up a new Hella one (that is OEM) from Mode for £165, as the gearbox builders wouldn't warranty my rebuilt gearbox without a new one fitted. I've still got the old one that's been through a parts washer Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350405 3rd Oct 2015 12:32am
Oh they are quite pricey then Embarassed .
Post #350407 3rd Oct 2015 1:41am
Cryptic
Yeah, thanks. Going to check the lot - rad, pipes, cooler & do the fluid & filter
Post #350428 3rd Oct 2015 9:18am
miggit
Unfortunately the oil cooler isn't an oil cooler Shocked it's a heat exchanger, which dumps the heat from the gearbox oil in to the water system to cool it. As far as cooling goes it works very well as it also helps to get the gearbox up to working temp quicker than the old fashioned air cooled rad.
But this is where the positives end Sad , if it becomes blocked or damaged it's a lot more expensive to replace. And if more cooling is required, due to heavy loads on the transmission, it is very difficult to increase the cooling area. I am still divided as to it's benefits over an air cooled system.
I can see that if you are in colder climates, the heating effect is very beneficial for the gearbox, and as such the system does work very well. But if your using your ffrr as a tractor it is not quite so easy to increase the cooling for the gearbox, in fact I haven't found away of doing this yet and really need to, anybody? Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #350465 3rd Oct 2015 11:46am
Cryptic
In the end, I didn't do the fluid change and cooler \ rad checks myself - time being the issue.
Anyway, the mechanic has come back saying problem not cured and it's time for gearbox out & strip. Quote for that is £1700. Censored
A quick google finds several places offering RR recon gearboxes delivered or car collected & fitted - some with warranties e.g.
http://www.birchmotors4x4.co.uk/#range-rover
which at £1100 with 1yr warranty is considerably better.
So my question to you guys is do any of you have any recommendations for gearbox specialists - ideally nr Manchester, or failing that, who would collect car?
Thanks folks
Post #353661 22nd Oct 2015 6:44pm
Personally I wouldn't go anywhere near these cheap places, having stripped mine down to see the awful work done on the box before these people are nothing but cowboys, they know what will last just outside the warranty, that's if they'd even repair it within the warranty period, they'd just come up with some feeble excuse and not pay...
Go to someone who is recommended by real people you know.... Pete
Post #353662 22nd Oct 2015 6:54pm
I had a look at this, but with the new box, cooler and lines mine stays well within it's temp range even when off roading all day in low box up hills.... they did design it to tow a 3 ton trailer across the Sahara, even your blue tac box should be OK..... Pete
Post #353663 22nd Oct 2015 6:58pm
Cryptic
Fair play, Pete. In terms of recommendations, I'm in the forums' hands...
Post #353664 22nd Oct 2015 7:00pm
