Home > Maintenance & Mods (L322) > Rear hub ball joints - MOT advisory |
Never knew there were balljoints on the rear, there are rear lower bushes (2 large) rose bushes (2 small) and 2 rear track arms so maybe them they were thinking of. |
12th Oct 2015 9:38pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1700 |
Rear hub ball joints have many names, of which rose bushes/joints are one
12th Oct 2015 9:43pm |
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 |
It looks like a fairly straightforward job for a specialist 4x4 garage. Any idea how many hours labour? |
12th Oct 2015 9:46pm |
Less than 3 hours, providing nothing unforeseen crops up
12th Oct 2015 9:49pm |
Don't mind paying a garage to do it, provided I'm not overpaying. I don't have the kit/time/know-how/patience. Bit disappointed with the MOT. I know they're doing their job, but 'slight' shouldn't be an advisory imho. They could've mentioned it to me rather than make it part of the cars permanent record. |
12th Oct 2015 9:52pm |
Thanks for your reply. |
12th Oct 2015 9:58pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Best to get it sorted sooner rather than later, as you plan too, otherwise you will start to see some severe tyre wear either on the inner or outer edges, meaning more £££!
12th Oct 2015 11:14pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7949 |
They called them balljoints because most people wouldn't understand the term Heim Joint or Rose Joint (Rose Joint is to Heim joint as Sellotape is to clear sticky tape....)
13th Oct 2015 12:47am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I expect the MOT computer system has a limited number of terms that can be used. Likely to be only Ball joints or Bushes, so they picked the best option. |
14th Oct 2015 6:05pm |
