Home > General > Possibly returning to a FF
SteveF
I am seriously considering getting back into a Range Rover again after having fun in an XKR 5.0 Supercharged for the past two years. Looking currently at either the 5.0 SC or 4.4 TDV8 in Vogue SE or Autobiography guise from say 2010-2012 MY.
Any advice from owners of either model would be appreciated and if someone could clarify which of the 4.4 TDV8 models have the 8 speed box that would be helpful.
Cheers
Steve
Post #352222 14th Oct 2015 2:24pm
hi steve, you need to change that 'possibly' to 'i will'...you know it makes sense.. Mr. Green
all 4.4 tdv8's have the 8 speed box, the 5.0 sticks to the 6 speed..
there are loads of threads re the trim and model differences in this section so this will help you.. ... - .- -.
Post #352230 14th Oct 2015 2:57pm
As Stan says, all 4.4 are 8sp, the facelift tdv8's with a gear knob are 3.6's Thumbs Up
Go on you know it makes.......well actually it makes no sense at all...... But you know you want to Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #352266 14th Oct 2015 7:43pm
SteveF
Thanks Stan and NMJ....I guess that i do know "i really want to"....but looking for real life experiences on both models as my way of carrying out due diligence before i go out hunting for the one for me.
Cheers
Steve
Post #352513 16th Oct 2015 9:57am
Go for the 5.0 if you can as they are just coming into sub £30k now and will likely be cheaper long term compared to the 4.4
If you want to save some pennies for £10k less you can get a 3.6TDV8 which while more frugal to a certain extent is well known as to its main issues and can be easily sorted. With the money saved you can get a remap, DPF/EGR delete to help with longevity and do all the fluids on it as well and still be much better off as it will lose less when you change your mind again in a few years time compared to the 5.0.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #352520 16th Oct 2015 10:40am
i drive both on a weekly basis and own a 4.4TDV8... Enough said Whistle
Post #352523 16th Oct 2015 10:47am
SteveF
Thanks KP.
Craig what are the differences with the two that made you opt for the 4.4 TDV8? Do you see any issue with the diesel with regards to relatively high miles (say 90k in 4 years).....i would only using the car for approx 8/10k year going forward.
Steve
Post #352542 16th Oct 2015 11:46am
