![]() | Home > Maintenance & Mods (L322) > Fitting New Osram DRLs |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
sub'd 2014 FF Autobiography 5.0 SC
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i'm curious to know why you have dismantled the whole front to fit some drls... ... - .- -.
^^^ same. I'm thinking he has some sort of stealth lamps or is doing some wizardry that i definitely want to see. 2014 FF Autobiography 5.0 SC
| shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 114
Today I prepared the harness with thermo sleeve, sealing and tucked routing...
Right connector: Green wire to Pin 8
Red wire to battery
Bumper connector: Black and Yellow wires to Fog Lights pins
Left connector: Grey, white and blue wires
I want to see the actual lights 2014 FF Autobiography 5.0 SC
Osramīs need to dremeling the support to fit, very easy.
I added the new bezels...
DRLs
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
They are VERY good lights arnt they |
Yes, very good!!
have you wired the cornering function sir? |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
I was looking forward to seeing these fitted. They suit the car very, very well |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Very nice, you have done a very thorough job, that rusty seam you cleaned off will re rust unless you have put some antirust treatment inside the box section to get into the seam, the rust is from the unpainted edges that were welded together... Pete
