![]() | Home > Maintenance & Mods (L322) > Fitting New Osram DRLs |
| shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 114
Also I added a new painted bar...
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
The Canbus signal is different so won’t support it sir |
Thanks Craig! I don´t like to wired this at turn lights.
Thanks Pete, I've painted this with anti rust coat but you have reason, this will need a deep treatment! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
There are lots of ignition live wires in the waterproof box under the bonnet, I needed one for the fans, just had a probe about with a meter till I found one then ran a relay from it... Pete
Yes...there are a lot of wires!!
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
great work. Been wanting to upgrade the stock fogs on my 2008 to LED but have not b/c I don't want to deal with the headache of splicing/tapping into wires/relays and the malfunction lights on the dash etc.
Finally, I've dismantled whole front for rewiring correctly. Osram´s permit a optional wiring to have a 80% of DRLs when position lights is enabled. Instead of connecting the brown wire to ground must be connected to positive, and the dimmer effect is achieved....I like this! Also I made the new wiring to so that the system can be removed without cutting wires.
My "technique" to weld: First, I removed the pin from connector and retired the seal. I sanded the pin with a file and insert the wire, then weld it. Insert the pin into connector and seal. Secure with strip.
Pete, I found the appropriate wire! When ignition turned off allows DRLs 20 seconds courtesy and then off. Perfect! In the row, third connector (black)
I welded the blue wire...
And power wire...
Routing harness...
Clean!!!
Reinforcement bar mods...
Now I work to embed the Osram fuse in the FFRR fuse box. I bought a Mondeo fuse box to try to do it.
Small connector for position light (white). I left a wire ready for cornering lights. (grey)
Hi, I approach to the end...
