Home > Maintenance & Mods (L322) > 2002 Dashboard - squeaky dashboard top screws
CY
2002 Range Rover Vogue Td6 Epsom Green
Hi All,
I recently removed my dashboard top so that I could respray all the walnut wood piano black and also replace the navigation unit.
Since refitting it, I have noticed a squeaking coming from the dashboard top. I've located it as coming from the 8 (?) long screws which go into the dash to secure it in place. When terrain gets bumpy, these click and squeak from all sides of the dash. I have tried tightening them and loosening them but they still seem to squeak.
Does anybody know how I could address this? I don't know if new screws would help (are these available?) or if I need to put something between them and the dash to soften the friction?
Keen to sort these as I love a quiet car!
Thanks,
Chris 2002 Range Rover Td6 Vogue
Post #353438 21st Oct 2015 10:42am
johnboyairey
i had this, one was loose, have you rechecked them? maybe get someone to lean over and sort of hold the dash at various places to absorb the squeak. -have you had the speedo out?
Post #353445 21st Oct 2015 11:22am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yes, I had the same problem a while ago when I had the instrument panel out to fix the pixels.
I bought new screws as I found a couple of the originals weren't biting fully after being removed a couple of times and that fixed the squeaking - they are about 30p each and the part number is FYP000341 (I think - Dan @Duckworths would be able to confirm for you) Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #353507 21st Oct 2015 6:46pm
steptoe
Very lightly grease the screws. Funnily it also helps them grip.
Post #353519 21st Oct 2015 7:46pm
CY
Thanks all!
Yes, I removed the speedo for pixel repair at the same time and when I put it all back together again two of the screws didn't 'bite' so it's probably not all latched down as tightly as it should be.
Many thanks for the details on the screws - I'll order these from Dan. Is there anything else I should do when the dashboard is apart again to reduce this ticking/squeaking?
Thanks again,
Post #353638 22nd Oct 2015 4:24pm
Make sure it's locked home properly, as you push it down and back you can get some of the clips over the top of where they should go and some under...
When you take it off, look for areas where there is dust created from the plastic rubbing and squeaking, then fix what's wrong, mine has little bit's of sticky backed foam in places, these look like they have been fitted by someone trying to stop it squeaking so maybe that's an idea as well....
If all else fails, turn the radio up... Whistle Whistle Pete
Post #353649 22nd Oct 2015 5:23pm
johnboyairey
do i remember on mine, that some screws were longer than others, so some dont 'bite', or do they not enter the holes and just turn freely next to the correct hole, meaning, they are as good as 'not there' ie dangling, but not screwed? i think i did my speedo, and then the centre speaker wasnt working, then i had squeaks, then i found i had a bolt missing,, then i found it, then i took them all out and tried again.
sounds like the typical way i work...
Post #353652 22nd Oct 2015 5:31pm
The seven big ones on top of the dash are all the same length... Pete
Post #353656 22nd Oct 2015 5:37pm
