|  | Home > Maintenance & Mods (L322) > 2002 Dashboard - squeaky dashboard top screws |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035      | i had this, one was loose, have you rechecked them? maybe get someone to lean over and sort of hold the dash at various places to absorb the squeak. -have you had the speedo out? | ||
|  21st Oct 2015 10:22am |
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560    | Yes, I had the same problem a while ago when I had the instrument panel out to fix the pixels.
|  21st Oct 2015 5:46pm |
| steptoe Member Since: 23 Jul 2012 Location: london Posts: 382    | Very lightly grease the screws. Funnily it also helps them grip. | ||
|  21st Oct 2015 6:46pm |
| CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146    | Thanks all!
|  22nd Oct 2015 3:24pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Make sure it's locked home properly, as you push it down and back you can get some of the clips over the top of where they should go and some under...
|  22nd Oct 2015 4:23pm |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035      | do i remember on mine, that some screws were longer than others, so some dont 'bite',  or do they not enter the holes and just turn freely next to the correct hole, meaning, they are as good as 'not there' ie dangling, but not screwed?   i think i did my speedo, and then the centre speaker wasnt working, then i had squeaks, then i found i had a bolt missing,, then i found it, then i took them all out and tried again.
|  22nd Oct 2015 4:31pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | The seven big ones on top of the dash are all the same length... Pete
|  22nd Oct 2015 4:37pm |
| Posting Rules
