Home > Technical (L322) > Rear heater is cold?
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi folks.
My heater in the back is always cold, the front
One is perfect. Any ideas?
Regards
Gary
Post #354383 27th Oct 2015 8:07pm
You do know it has an adjuster for rear temp next to the outlet in the rear... Whistle
Just thought I'd mention it.... Pete
-Click here for Thread-
Post #354384 27th Oct 2015 8:18pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Re: Rear heater is cold?
Got the same problem.. Front hot as hell, rear - ice cold.. Also i sounds like a jetplane when ypu crank the speed up... L322 Vogue 2003
Post #354389 27th Oct 2015 8:52pm
sako243
Don't know about pre facelift cars but mime has a button bottom right of the centre console which enables / disables the rear heater controls. If you have the light on then the rear controls are active, otherwise they match one of the two front controls. Which one I don't know/can't remember...
I quite often have it switched to the rear if the dog is in the back to keep her cooler. Ed
Post #354390 27th Oct 2015 8:56pm
Eirik34
Norway
We experience the same on our 07 ffrr - mostly cold air in the rear air vents, regardless of how I set the rear temperature adjustemt knob. If I turn on the rear AC with the "real AC knob" on the front panel, the rear air is a bit less cold, but far from as hot as it is at the front.
I think I've read somewhere that the interior in a ffrr is built around the AC system, and that it is designed to make the total experience as comfortable as possible. So maybe the rear air vents SHOULD blow colder air? Anyone that knows how this is designed to work?
Post #354397 27th Oct 2015 10:49pm
Garyfax
Thanks folks.
Yes I think I know how to operate it but it's just cold air and it won't come warm.
I was thinking it could be some sort of solenoid or something but just guessing really.
Any more ideas?
Gary
Post #354416 28th Oct 2015 8:02am
IIRC its tied into the passnger heat setting as well so worth whacking that up and see if it makes a diff FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354438 28th Oct 2015 10:38am
not tried this myself but would the front center horizontal dial that controls the center/side vent temperature also control the overall heat to the rear center vents...
this one,
Post #354447 28th Oct 2015 11:03am
Post #354449 28th Oct 2015 11:11am
From the manual,
Note: The temperature set by the front occupants restricts the maximum level of warm air the rear passengers can select.
No mention of it being linked to a specific side in the front, or being linked with the face level vents in the front...
I know for a fact the floor vents in the rear are connected to the front heater and not controlled by the rear, so it would appear the rear centre vents maximum heat output is the setting that the front vents are at.. i.e. you can't have the rear vent hotter than the setting in the front... Thumbs Up Pete
Post #354454 28th Oct 2015 11:32am
Garyfax
That's interesting.
My rear heaters feel like the aircon is on full if I open the vents. I will take it to my local Independant and
let you know what they say.
Thanks folks
Post #354611 29th Oct 2015 4:59pm
Eirik34
Norway
Did you found out what caused the cold air in the rear vents?
Post #356580 12th Nov 2015 11:54pm
Garyfax
Unfortunately not. Still cold for passengers in the back.
Post #356911 14th Nov 2015 5:46pm
