Home > Technical (L405) > On the subject of weird noises....
MattyB
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
In my MY2016 TDV6 I can hear a really irritating whining noise coming from the near side of the engine compartment. It does it from cold and in the short 6 miles to work it doesn't go away - well it fades to almost no noise when I'm moving but as soon as I stop in traffic or am crawling along, back it comes.
My old L322 TDV8 did something slightly similar and someone told me it was maybe the heating unit but in that car it used to stop making a noise pretty quickly whereas in the L405 it doesn't go away. This is supposed to be a refined, quiet car but it sounds cheap and unrefined, at least on the short daily commute.
Any ideas anyone?
Post #352581 16th Oct 2015 4:11pm
dfulgo
Italy
Geiger Counter noise
...well, mine is three weeks old (ATB TDV6) and, since the beginning, I've noted this Geiger Counter type noise that I've started investigating by changing various "configurations" in order to find out its origin and, for now, i think I may have found the culprit:
- Outside Temperature below 18°C. ☆☆☆☆
- Sunny / raining whether ☆
- Bad road / normal paved road ☆☆
- Pano Roof shade extended / not extended ☆
- Widows open / closed ☆
- Speed above 70 km/h ☆☆
- Only driver vs. four occupants ☆
- Air recycling on ☆☆☆☆☆
therefore I suspect that my Geiger Counter noise "could" be connected with a climate vane movement or bad positioning. I'll have the dealer check it @ my next visit planned by next week or so where he have also to:
- change right front door inside panel slightly damaged before delivery
- activate automatic lights
- make rear lights off with daylights
- make front parking aid auto-activate as per menu and owners manual
- make the HUD plastic properly match the dash shape
...but I love my FFRR anyway, fantastic.
Post #352612 16th Oct 2015 7:40pm
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
Dfulgo...... Problem with auto lights (high beam) on 16my, LR are due to produce software fix..
Post #352631 16th Oct 2015 10:30pm
d3rm0
If you press and hold the P for 3-5 secs it will switch to auto Thumbs Up
Post #352656 17th Oct 2015 7:37am
dfulgo
Italy
@ modbarra: that's good news, thank you.
@ d3rm0: it doesn't work on mine, nor works the option in the centre screen: each time I turn it on it becomes off at every new start. It looks like a software bug on cars without the auto parking feature, I think they forgot to paste few lines of code in cars with parking aid only feature, but this is only my supposition.
Post #352658 17th Oct 2015 7:51am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I have full parking aid on my L494 and have the issue with the front sensors. LR know it's a software bug but they 'all do it' - yes they all do it wrong contrary to the manual!
Please kick up a fuss or we don't have a chance of getting it changed. There is no point having this feature that resets on ignition cycle.
Post #352693 17th Oct 2015 10:39am
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
When i press P for 5 secs it says park aid unavailable please consult dealer, does that mean I don't have it ir its knackered?
Post #352725 17th Oct 2015 3:54pm
dfulgo
Italy
Laughing that's really funny, I "should" have it but it doesn't work at all. .., is your supposed to have it?
Post #352726 17th Oct 2015 4:02pm
Autobiography
It means you've fully disabled PDC and AFAIK the dealer needs to re-enable it. 15MY introduced the new feature. 16MY changed how you enable the feature but 15MY doesn't forget your choice at ignition reset!
Post #352781 17th Oct 2015 9:51pm
Ms. Mdx
United States 2015 Range Rover Autobiography 5.0 SC V8 Scotia Grey
dfulgo, does your ATB have the premium sound system with Conversation Assist (CA)? You might want to test that it isn't your CA that is picking up a rattle and broadcasting it over the speakers. You can turn CA off in the menu to test it out. 2015 RR ATB (Scotia Grey w/Cirrus-Ebony)
2014 MB E63 s/AMG
2010 Acura MDX
Post #354675 30th Oct 2015 4:44am
dfulgo
Italy
Thank you Ms. Mdx, but, I think no. I've checked it as soon as I read your precious previous posts on the matter and I found out that:
- my system is the 825 so I'm not sure the CA is even available on it
- no CA options in both Centre Screen & Dash
- no CA mention on my Topix Build Sheet
BUT Shocked
...yesterday evening I really found the culprit! Now I can replicate it: it is my beloved leather lined frame of the sunroof, if I depress the edge which is right above the driver's head, like trying to push it against the glass-roof, then the Geiger Counter noise can clearly be heard. It is more evident with the blind extended AND the same phenomenon is also present on the back.
Next monday the appointment with the dealer, I'll keep you posted.
Thanks again.
Post #354678 30th Oct 2015 8:28am
Chaffers
United Kingdom 2013 Range Rover Vogue TDV6 Aintree Green
Full Fat Flatulence
Mine has started making what can only be described as a farting sound, when you turn it off. Yesterday and today, about a minute after turning off the ignition, from the drivers side rear .. No change in ride height when it's sat there or anything like that, but just seeking opinions (and assurance!) thanks!
Post #362149 14th Dec 2015 9:36am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Chargers - it's probably to do with fuel tank, is it quite low on fuel?
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #362157 14th Dec 2015 10:13am
Chaffers
Hi Nick, thanks for the reply. I've actually just filled it up what with Morrisons doing 102.9p, but I'd not even thought about the fuel tank.
Post #362162 14th Dec 2015 10:24am
Chaffers
Bizarrely now I've un-tightened the fuel cap, which resulted in a vacuum type sound, it's stopped doing it, so I guess Nick you were on the money - thank you!
Post #362717 18th Dec 2015 10:32am
