Home > In Car Electronics (L322) > Fuses td6
Page 1 of 4 1234>
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Fuses td6
Could some one advise me to which fuse controls td6 indicators please.
Post #355722 7th Nov 2015 3:48pm
There aren't any fuses for the indicators. The bulbs are supplied and monitored for faults by circuitry inside the Lighting Control Module.
Whats your problem?
Post #355728 7th Nov 2015 4:07pm
brian1951
Thank you for your prompt reply. Well i jumped in the old girl this morning and noticed i had no radio ( not the end of the world ) Then when i reached the end of the road and indicated i noticed no indicators. So i thought fuse maybe
Post #355730 7th Nov 2015 4:13pm
You could try disconnecting the battery for a few minutes and see what happens.
You could also wait and try again tomorrow, everything might be working then. Thumbs Up Smile
Post #355732 7th Nov 2015 4:18pm
brian1951
Thanks for your advice, will try the battery idea and report back. Regards Brian.
Post #355735 7th Nov 2015 4:21pm
brian1951
Tried disconnecting the battery. no change im afraid. Will see what tomorrow brings Bow down
Post #355741 7th Nov 2015 5:02pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
I had that happen to me as well, check in the back where the amp and other bits are i found it was down to water ingress gone fishin'
Post #355782 8th Nov 2015 12:24am
brian1951
No sign of water anywhere nice and dry Big Cry
Post #355821 8th Nov 2015 11:03am
Do your hazard warning lights work?
Post #355827 8th Nov 2015 11:40am
brian1951
Yes they do
Post #355829 8th Nov 2015 11:46am
That tends to suggest to me that you have a fault connected with the column switch for the indicators.
There's only two switches for the indicator lamps, the column switch and the hazards switch. By virtue the hazards work it means everything works bar the input from the column switch. That's where I'd be looking.
Not sure about your radio but as you say you can do without for now. Thumbs Up
Post #355832 8th Nov 2015 11:58am
brian1951
I did notice the hazards were silent and the two green lights in the instrument cluster are not flashing either when the hazards are on. I do appreciate your help and time on the matter. Looks like time to get the tools out.
Post #355834 8th Nov 2015 12:04pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had the same issue a few years ago - disconnected the amp etc in the rear and cleaned all contacts with a fibre glass pencil - put back together and all has been well since.
Post #355837 8th Nov 2015 12:33pm
brian1951
Well done Merc, I have just been hunting for the amp which i presume is the black block under the sat nav. Gave the leads a wiggle and hey presto all works again.
Post #355839 8th Nov 2015 12:44pm
Thumbs Up How that clears the indicators is totally beyond me. Laughing
Post #355843 8th Nov 2015 1:00pm
Page 1 of 4 1234>
