Home > Maintenance & Mods (L322) > Bosch Aero Retrofit blades?
Page 3 of 5 <12345>
miggit
Laughing the day-glow wipers caught me out too! Laughing
Glad it all went fairly painlessly.......... of cause someone had to discover that the passenger side was easier to do Embarassed Banging Head Banging Head Evil or Very Mad
Now that I have tested the new blades, it makes wonder why I Censored about trying to save the drivers side clip in the first place Thud Yesterday I couldn't spell Engineer... Today I are one!
Post #355975 9th Nov 2015 4:14pm
Miggit,
Thanks for the replies, I have bought a set of these, can't wait to try them. Thumbs Up Discovery 4 HSE
1993 90 Tdi
Post #356044 10th Nov 2015 9:42am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I bought a set as well, not fitted yet as its being blowing a gale here.
Is there something to remove from the blade then?
Ian
Post #356061 10th Nov 2015 11:08am
from the wiper arm there is Ian, mentioned a few posts back... ... - .- -.
Post #356064 10th Nov 2015 11:16am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I think it depends on which wiper arms you have. If you have the hook type them maybe not as it seems you just open the plastic fitting and hook them in. If you have the type described above then you need to squeeze together the two sides of the plastic fitting and completely remove it from the metal arm before clipping in the new blade. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #356066 10th Nov 2015 11:21am
miggit
Question Where dose this bloody hook type wiper fitting keep coming from? Shocked
I have looked on several parts websites and they all say that the L322 from 2002- 2012 have the same wiper blades, and the ones that I had were not the hook type Evil or Very Mad
The rear IS HOOK TYPE, the front ARE BMW CLIP IN, totally different and not cross compatible or interchangeable with each other.
So unless you have changed the wiper arms (which I very much doubt is possible except with factory fit) you have the BMW Clips NOT HOOKS Banging Head
Right I have found where these bloody hooks are coming from, some of the wannabe Range Rover Sport's have hook type arms, not the L322 Vogue, so unless you is on the wrong site, you have to remove all the plastic bits from the metal wiper arm to fit the new Aero wipers. The easiest way to tell is the BMW clips have a a small arrow and the word "LOCK" embossed on them
You need to remove all of this from the end of the wiper arm
And all of this from the drivers side Shocked
You will then be left with this
Simples Thud
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #356079 10th Nov 2015 1:33pm
IanV8
Fitted mine last night, dead easy 2 minutes for passenger side and about 4 minutes for driver side which is harder because of the spoiler getting in the way.
And I did remove the green protectors.
Ian
Post #356227 11th Nov 2015 10:39am
Nomad
Just drove mine in light rain. Still a light thump at the end of each swipe but nowhere near as bad as the clunk on the old ones. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #356238 11th Nov 2015 11:51am
miggit
They are not totally silent at the top of their travel, but they also aren't maddeningly deafening either Mr. Green and they are super quirt getting there Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #356282 11th Nov 2015 3:45pm
Mine arrived, fitted with no problems but they still clunk as much as the Bosch 808s did, not really any quieter unless its different at speed.... Discovery 4 HSE
1993 90 Tdi
Post #356904 14th Nov 2015 5:25pm
miggit
^^ can you hear it over the radio at start up volume, assuming that it comes quirt at the same level regardless of the ear bleeding level it was switched off at Shocked If you can then yours are noisy, if you can't then I would suggest that your Bosch wiper were quirt to start with Shocked Shocked
I had to turn the radio up to hear it over the wipers, we is talking more of a thud at the top of it's stroke Evil or Very Mad now it is just a little clunk, as if to say I'm still here Wink
Plus your ffrr has 7 years less wear in the linkages, I bet that makes a difference too Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #356975 15th Nov 2015 1:49am
So come on chaps, what is the approved (or your) method for separating the original fitting from the arm, everyone says it was a PITA to do, but no-one describes exactly how? Does one "simply" prise it out by levering on the sides of the arm?
My new Aero blades have been sitting in the garage since Christmas and it is time to fit! Thumbs Up .
Post #374566 27th Feb 2016 8:02pm
miggit
The N/S (passenger) ones are easy, remove the old blade and just squeeze the plastic in to the middle and it will free it's self. It should be the same for the drivers side, BUT, the aerofoil makes it all rather rigid, and the fact that it's stuck in the middle of the windscreen doesn't help either. In hindsight it would be an advantage to do the N/S first, then operate the wipers and stop them at the top of their travel, which would then make the drivers easy to get at, Censored why did I only just think of that Censored Censored
Recon that having a small screwdriver to hand for prodding and the like, could be an advantage too Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #374584 27th Feb 2016 9:29pm
Weegie
When I got my FF the wipers clunked maddeningly as described. I fitted Bosch 808 nineteen months ago and they make no noise at all. Surprised that people are reporting noise. Wonder if it is down to adjustment of the arms rather than the blades? John
GAP iiD BT-Sold
Post #374609 27th Feb 2016 10:59pm
Thanks Miggit, tomorrows job Smile .
Post #374621 28th Feb 2016 12:49am
Page 3 of 5 <12345>
