|  | Home > Technical (L322) > Thoughts please chaps,Alternator and battery.for a change!! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      |
 New 110Amp Varta big boy July 2014
|  13th Nov 2015 3:04pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | dont know if its any help but my charge is 14.1 volts and i have no problem starting. mind you its a 4.2 petrol so whether that makes a difference? ... - .- -.
|  13th Nov 2015 3:26pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Just a thought bud, have you driven the car and then disconnected the battery to see if it holds it's charge overnight?
|  13th Nov 2015 3:32pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | Ditto the above really. Charge the battery and leave disconnected overnight, then check it. TBH, it does sound more like the battery. If it holds a charge fine when disconnected, it's worth checking for a current drain.
 14V should be absolutely fine, but look into it in detail and it might reveal a spikey/irregular output. Am I right in assuming your IID is a BT? If so, might be worth graphing the voltage and RPM.  Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  13th Nov 2015 4:14pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Cheers chaps... I'll give it a good charge and then leave it disconnected and see if the battery will hold the charge..
|  13th Nov 2015 4:40pm |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267      | Am no expert but if you have 14 volts it will not be the alternator .I haad a similar problem myself just last week,new battery last xmas and been fine until September when I left it for nearly 2 weeks and it would not start.I gave it a full charge and it was ok for a month then the same after a week stood,i partially charged it to get started only for the dreaded 'bong'..'air suspension inactive' followed by various other bongs as I drove down the road.Gave it a full charge and my mate to reset the fault codes so I have had enough and am going to wire it up to a charger like some others have.My mate reckons it is not the best to wire into the rear connections as some go through relays so I have ran a 2.5mmtwin from the battery along the line of the brakepipes up into the wheel space and out by the trailer adaptor.I havnt connected yet as my mate is getting the connections so hopefully be able to plug in when it is parked up over winter anyway.When the battery has dropped its voltage the systems are sent mad and constantly switch on and off which drains the battery quickly unless it is fully charged ! | ||
|  13th Nov 2015 10:00pm |
| Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315      |
|  13th Nov 2015 10:09pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Thanks chaps, I'll give the battery a test and if there is a draw on it I'll track the little   | ||
|  13th Nov 2015 11:35pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | As an alternator is basically an AC generator it is possible to have some of the stator windings break down and reduce the current but not the voltage, I believe that there are 6 separate windings in the average alternator,and if individual windings were to fail you could loose a sixth of your charge, but still show 14 volts   | ||
|  14th Nov 2015 12:11am |
| RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187      | Pete,
|  14th Nov 2015 8:09am |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | It doesn't seem to be as simple as that, with the battery at 50% charge you would think that the alternator would put out 14.(whatever) volts at it's maximum amps but it doesn't, the voltage is all over the shop with no rhyme or reason to it, and it did this with the old one and this one since new...
|  14th Nov 2015 12:52pm |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | When testing the standing charge leave the car an hour after driving before testing. 12.6+ is what I look for/want. | ||
|  14th Nov 2015 1:44pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | You don't happen to have a bad connection somewhere by any chance?
|  14th Nov 2015 2:27pm |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459      | Pete - I have a cheapo voltmeter connected to the lighter socket. I calibrated it (small trim screw on the back) about 6 months ago. Just checked it and now reading .2V less than it used to - so I would check your voltmeter guage against ... well... a voltmeter.
|  14th Nov 2015 9:22pm |
| Posting Rules
 down and show it the door.....
 The red light is only controlled by one segment of the alternator, so it could all look OK but instead of throwing out 120 amps it might only be giving 20 amps
