![]() | Home > In Car Electronics (L322) > Fuses td6 |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
A update on the problem, indicators still working and radio has sound BUT no display or sat nav, weird indeed. |
The fault with the display is down to a corroded pin in the TV/ENTERTAINMENT UNIT YIL 000023 . So has anyone attempted to repair one or is it just a case of buying a new unit. Is ok to drive with this unit removed. |
Help please guys |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
If this is the tv module you can disconnect the blue and white plugs from the module, discard it and then reconnect the plugs directly from the satnav module to the radio module and everything will work as before bar the tv.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Could try cleaning up the pins with a bit of contact cleaner / emery cloth / sandpaper / flat screwdriver / whatever you can find Howard
Thanks Nicedayforit, i will try your idea tomorrow. |
They have gone past cleaning SMUTT in fact two went walkabout. |
Just make sure you switch the ignition off and wait until the red light on the satnav module goes out and then slacken the nuts holding the unit in the mounting frame, pull the unit forward out of the frame and then disconnect the cables. Once out of the frame plug the cables back in and look to do what I can't remember. ![]() ![]() |
Cheers for that niceday, i did notice that red light on sat nav is NOT going out even with the keys in my pocket |
It should eventually, can take 20 minutes I recall.
I know one thing for sure l405 has got a lot closer now. |
Classic symptoms of water ingress to the boot area as a result of the rear upper tailgate seal failing. |
Thanks niceday for that link ( it could be the route i end up taking ) As for now all four units are in the drying out process, i will then take apart clean and refit and see what happens. Thanks again for your time and help in this, will report back when im done. Brian. |
