Home > For Sale & Wanted > [SOLD] FREE OF CHARGE - Snow Chains for 255/50/20
They are getting in my way now - and if I put them back in the shed they will stay there forever - so another week & they will go in the bin, which would be a shame.
Only ever fitted on my drive so I was sure I knew how they worked - didn't want to be caught in a snowstorm in the dark trying to figure it out for the first time.
Other than that, never used, but have accompanied me on many a trip to the Alps.
They come in a carry case.
Collection from Peterborough - or I could meet in Central London - or postage would be £13 with my usual courier - or you can sort out your own collection - I'm not bothered really, just want shot of them.
Post #357850 20th Nov 2015 9:47pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Will they fit 255/55/20, if so sold. letters not necessarily in the right order
Post #357855 20th Nov 2015 10:13pm
I honestly have no idea - there is definitely some latitude as there is a tightening process
TBH, I think 255 55 20 might be a stretch too far though
I think they would fit the 255 55 19 as the diameter is about the same - not that its much help - but think that extra inch or so diameter might be too much
If you were closer, you'd be welcome to try them - but I only have 275 40 22's
Post #357863 20th Nov 2015 10:31pm
Comparison
1" diameter & 3" circumference
They came with a leaflet that listed a bunch of other sizes - which I lost - but from memory were all sorts of different with, aspect ratios & diameters - but no 2 were similar, so I thing 50 to 55 is unlikely to work
Big Cry
Post #357869 20th Nov 2015 10:46pm
Matricks
Hi,
As it happens i'm looking for an exact set of these!
PM inbound.
Thanks
Matt
Post #359856 30th Nov 2015 9:27pm
CS
I have a set of these chains (LR accessory VUJ000020). The brochure says they are for 18" and 19" rear wheels only, not 255/50R20. The LR accessory for 20" wheels is the "snow traction system" LR005737 which is used on the front wheels. Looking at the 405 accessory brochure the snow traction system looks very similar, but has the part number VPLGW0081. Only Range Rovers since 1988
Post #359931 1st Dec 2015 2:50pm
I can't see a reason that a set of chains which fit the 255 55 19 or 255 60 18 won't fit the 255 50 20s as the rolling radius is the same. this means that the edge of the tyre is the same difference from the strut, and as the width of the tyre is the same then there shouldn't be much trouble fitting them.
I have a generic set for 19" which I am planning to use on the 20" this winter trip if needed, unless anyone can give me a reason why not? There is nothing that can't be fixed with a hammer😜😜
Post #360572 5th Dec 2015 9:27pm
They will fit just fine - on the 20's you might find that the chain is close to the rim - that's the only reason I can think of why the official kit is more of a studded belt type arrangement.
The ones I bought for the 22's on the L405 are that style - Thule K-Summit XL's Thumbs Up
Just try fitting them at home to make sure you're happy with them, but I'd be surprised if you have a problem.
Post #360597 5th Dec 2015 11:53pm
CS
I agree that the sizes of the two systems should be the same, but as LR say 18 & 19 chains on rear wheels, 20 system on front, I would wonder whether there is something else to it. Miight the chain damage the rim of the 20" wheel as it needs a higher sidewall? And why the front/rear difference - might the chain catch something at the front?
I wonder whether LR Customer Relations might be able to say? Only Range Rovers since 1988
Post #360731 6th Dec 2015 8:28pm
Chains won't fit on the front at all - there isn't enough clearance - run your hand behind the tyre from 11 to 1 o'clock and you will see what I mean Thumbs Up
Therefore if you have chains they have to go on the rear.
However, if you have a belt type system like the Thule K-summit, then you could put them on the front.
I assume there is benefit in putting them on the front as you then have steering ???
Chains are close to the rim on 20's
The LR recommendation has to be based on extended use in the worst of conditions.
I'd have been happy with chains on 20's for crawling into a ski resort, but fortunately never had to fit them. I did, However, have to carry them.....
Post #360804 7th Dec 2015 4:08am
Now FOC Thumbs Up
Post #362056 13th Dec 2015 3:26pm
thats a bargain Thumbs Up ... - .- -.
Post #362059 13th Dec 2015 3:55pm
Baltic Blue
P M sent.
Post #362060 13th Dec 2015 4:02pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
There is a set of these on Ebay now item eBay Item No. 381485786977 at £329.99…listed for Discovery though?
Post #362061 13th Dec 2015 4:06pm
Dixy
Alistair wrote:
Now FOC Thumbs Up
Will that include you delivering them to Somerset. Razz letters not necessarily in the right order
Post #362064 13th Dec 2015 4:17pm
