Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK
Page 18 of 31 <123 ... 171819 ... 293031>
miggit
Pete, like the new avatar Thumbs Up is there any way you could get it to spin around like Marks did? only your not showing fatty in her full glory, maybe a before during and after water clip? (front middle and back) Yesterday I couldn't spell Engineer... Today I are one!
Post #360285 3rd Dec 2015 4:58pm
I have enough trouble getting one on there let alone several....!!!!! Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #360292 3rd Dec 2015 5:20pm
miggit
That'll be a job for Mark next time he's riding shotgun Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #360295 3rd Dec 2015 5:24pm
How about that then...?? took ages... I'll do a better one soon..... Pete
Post #360321 3rd Dec 2015 8:26pm
miggit
Bow down Bow down I'm in the presents of a Master Bow down Bow down
Nice job Bud, I'm impressed, but I suppose that will get upgraded as the car does Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #360349 3rd Dec 2015 11:38pm
Pete mate.........
Ahem...........
Have you changed your Avatar again pal??? Whistle Whistle Whistle
Nice Bow down Bow down Bow down Wink Thumbs Up
Post #360353 4th Dec 2015 12:12am
It's mk 1 just trying out the concept... more mods to follow....
(Craig did you get my PM??) Pete
Post #360358 4th Dec 2015 12:31am
RR2008HSE
THIS TIME I NOTICED!
Post #360476 5th Dec 2015 2:28am
Well done, glad your paying attention... Bow down Thumbs Up Pete
Post #360516 5th Dec 2015 2:54pm
miggit
Whistle Not a bad idea then? Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #360560 5th Dec 2015 8:18pm
Had four new tyres in October last year 275/65/18 General Grabber A/T2, the rears have worn out twice as fast as the fronts and although they still have about 5mm of tread left on them they received 7 (yes seven) punctures on the last off road trip, all minor which led to them slowly going down over several days, two in the very edge of the tread where the tyre places fear to go...
The fronts still have 8-9mm of tread and have had no punctures at all....
They have done over 14,000miles and a fare bit of laneing, they are substantially noisier now than they were when new...
So looks like I'll have to get a new set sometime soon... fancy having muds this time for a change, I won't be doing so many miles now and hopefully they will last a bit longer, there are a couple of 10ply LT ones around, may give them a try...
Now.... how much do I have to chop out to get 37's on...??? Pete
Post #361598 10th Dec 2015 11:11pm
miggit
In my experience 37" wheels would require a 6" lift and a fair bit of body removal...... you might find 35's easier Wink
I'm a wee bit concerned about your tyre wear report, is there something up with your rear end Matron?
I've been running General Grabber AT's on mine since I had that funny turn and brought the car, I've done just over 32K on my rears and they are showing no real signs of wear, in fact I'm having a hard time differentiating between the front and rear wear, and the rears are 5K older Thumbs Up
Word to the wise, be very very careful in the wet if you do get mud terrains, they have a nasty habit of letting go on corners without any warning, I had a few "new underpants needed" moments when I first had them fitted to the Landcruiser, got used to them in the end, but I would say that they had 60% less grip in the wet than the Falkern AT's that I was running before Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #361603 11th Dec 2015 12:08am
I would imagine it would take a dam sight more than that for 37" wheels, think how big the tyres would be... Rolling Eyes
Anyway it was a joke the diameter would be 25% bigger than stock and you can't get different diff ratios to sort that out, the TD6 is a bit better but nowhere near enough....
Thanks for the heads up about mud tyres, been driving on them on and off for 30 years so I know what they are like, if you buy the LT 10ply ones they are nowhere near as bad, the tyre is so stiff it doesn't move when cornering, they are actually much better than you would think.......
You should try driving on 750/16 Mud pattern crossplies to know what "no grip" really means!!!! Thumbs Up Pete
Post #361610 11th Dec 2015 12:24am
miggit
I soon found that the Kumho KL71's and wet tarmac don't really work well together Shocked But when you think about it the more aggressive your tread the less rubber you have in contact with the ground, somethings got to give.... generally grip on wet corners Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #361616 11th Dec 2015 12:38am
Or... the less rubber in contact the more PSI so more grip.... look at WRC rally cars on ice, the tyres are half the width of normal ones
The issue is the deformation of the tread block by sidewall bending when chucking three tons into a corner, the sidewall bends too much and lift the tread blocks off the road...
Light Truck 10 ply sidewalls tyres don't flex so much so more grip.... Thumbs Up Pete
Post #361619 11th Dec 2015 12:57am
