![]() | Home > Technical (L322) > bonnet release |
sounds like a broken cable... ... - .- -.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Do a search on here - there is a temporary fix - I seem to remember @NiceDayForIt did a write up.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Easy self fix. Make sure u know which end is kaput - cable is in 2 pieces and both are separate part numbers and come together inside the bonnet space. I will warrant it has chafed at the handle inside by the drivers door! |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 ![]() ![]() ![]() |
awesome cheers
got the panel off
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
Same just happened to mine, I just replaced the lot from Dan, new handle and bottom half of cable, it comes with the whole white plastic bit, you just need to use the screw that holds the handle on...
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Had the same on my son's audi quattro earlier this year. Just the plastic bit broke, easy fix but seems all manufacturers have adopted the plastic route. |
