![]() | Home > Technical (L322) > 2004 FFRR binnacle display language change? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Hi - I can't confirm the setting (as I'm not with the car) but it is accessed via the Screen display on your sat nav. (assuming you have this)
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
im still struggling and google hasnt turned anything up yet
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35799 ![]() ![]() |
dis-connect your battery for an ecu reboot.. ... - .- -.
tried poking around the nav interface (which is still English) and disconnect battery...but the pod display is still in French |
found this , hope it helps.
cheers...that does take you into config, but its for the nav unit rather than the car itself
then its a trip to the dealer i guess...i too wonder why it changes like that. ... - .- -.
another electronic quirk ...a bit like the random reboots of the nav ...its got a mind of its own |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
Its via the nav - I can confirm as a nice garage (sic) in Spain reset it to French after a visit (as it is a French car - what logic!). Cleared via the nav screen and now is happily "speaking" the queens english |
..you mean what i suggested four posts ago steve? ... - .- -.
yeah, you can change the nav language via the nav settings
just a thought..the button you press [on the stalk] when you go from one reading to another, if you keep that button depressed for a few seconds ,does it go to a menu select screen on the nav, if so is there something that can be selected there... ... - .- -.
yep, that goes to "prog" where you can select all the values you may/may not want to see....but not the bleeding language its in ![]() ive been looking everywhere for some button combo press that may do it, but even google doesent have the answer cheers bogie |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Hi chaps,
