Home > Technical (L322) > Replacing rear height sensors - is it difficult?
CY
2002 Range Rover Vogue Td6 Epsom Green
Hi all,
Last weekend when I was attending an off road driving day in the West Coast of Scotland, my rear suspension collapsed and after removing the rear O/S wheel I saw that the height sensor had snapped. I tied it back together with cable ties and it got me home... I've now purchased and received a replacement and am looking to replace tomorrow hopefully.
Does anybody have a tutorial or any guidance on how to do this please? I've searched through many threads on here but can't find a step by step guide.
Many thanks in advance
Chris 2002 Range Rover Td6 Vogue
Post #361875 12th Dec 2015 5:40pm
viper
I believe its just screw on , plug in and then it will need recalibrating by someone with the correct tool/software. My Indy did mine for £50 using his autodata machine
Post #361884 12th Dec 2015 6:17pm
read some where that it doesnt need calibrating, could be wrong though.. ... - .- -.
Post #361898 12th Dec 2015 7:20pm
It does require to be re-calibrated
Post #361909 12th Dec 2015 8:46pm
Thumbs Up ... - .- -.
Post #361911 12th Dec 2015 8:52pm
Honezgr8
United Kingdom 2004 Range Rover Vogue Td6 Galway Green
There was a youtube video where you got into a menu on the screen and were able to run the calibration from there...you can do it yourself fairly easily...
Post #363075 20th Dec 2015 3:39pm
rangie47
http://workshop-manuals.com/landrover/l322...ht_sensor/ 2007 tdv8 se ,stornaway grey
Post #363081 20th Dec 2015 4:24pm
Honezgr8
You were right:
Here is the link: https://www.youtube.com/watch?v=ayYbDiZXsV0 that I was thinking about.
It's using allcom software.
Post #363094 20th Dec 2015 5:17pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
i know the l322 is a complicated car, but on my old d2 i disconnected the battery to change a bad height sensor, then reconnected the battery.
the car did'nt know any difference, and was told that should need recalibrating.
did this twice, no problem.
but then i suppose they built in something so as it's not easy.
Post #363135 20th Dec 2015 10:09pm
viper
you will still need a calibration tool
Post #363136 20th Dec 2015 10:10pm
Zirconblue
I suppose in theory if you're very lucky and the new sensor is very close in tolerance to the old one, then in theory disconnecting the battery and changing it would work. But the odds of the sensor being near identical are very slim, so you'd end up with that corner sitting high or low as the new sensor will be sending a different reading to the ECU than it's expecting.
In practice though, you'd need a tool to tell the car the suspension level.
Post #363205 21st Dec 2015 7:10am
gregdav
Post #363212 21st Dec 2015 9:10am
Mikey
Or, just swap the link rods over Thumbs Up
Saves any calibrations needing to be done
Post #363215 21st Dec 2015 9:37am
CY
I got my indy to do it on Friday as a freebie whilst they had the car in pieces for its MOT anyway.
They said they then calibrated it but that corner is now sitting 4cm lower than the others...
Was going to go back to the garage but I'm expecting an iid from Santa Claus on Friday so may give it a go sorting it myself Whistle 2002 Range Rover Td6 Vogue
Post #363302 21st Dec 2015 4:59pm
