![]() | Home > Technical (L322) > Replacing rear height sensors - is it difficult? |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
I believe its just screw on , plug in and then it will need recalibrating by someone with the correct tool/software. My Indy did mine for £50 using his autodata machine |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
read some where that it doesnt need calibrating, could be wrong though.. ... - .- -.
It does require to be re-calibrated |
Honezgr8 Member Since: 29 Oct 2015 Location: Glasgow Posts: 3 ![]() ![]() ![]() |
There was a youtube video where you got into a menu on the screen and were able to run the calibration from there...you can do it yourself fairly easily... |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
http://workshop-manuals.com/landrover/l322...ht_sensor/ 2007 tdv8 se ,stornaway grey |
You were right:
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
i know the l322 is a complicated car, but on my old d2 i disconnected the battery to change a bad height sensor, then reconnected the battery.
you will still need a calibration tool |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I suppose in theory if you're very lucky and the new sensor is very close in tolerance to the old one, then in theory disconnecting the battery and changing it would work. But the odds of the sensor being near identical are very slim, so you'd end up with that corner sitting high or low as the new sensor will be sending a different reading to the ECU than it's expecting.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1835 ![]() ![]() |
Or, just swap the link rods over |
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
I got my indy to do it on Friday as a freebie whilst they had the car in pieces for its MOT anyway.
