Home > Technical (L322) > Towbar electrics 7 pin to 13 pin
Page 2 of 4 <1234>
Zirconblue
the non-genuine electrics aren't programmed, you can just unplug them, and replace with the genuine electrics unless the car loom has been hacked about to splice them in.
If you're only towing a bike trailer, and just want a 13pin socket because it's a better socket, then you can just replace the single 7 pin socket with a 13 pin, transferring the wires across, you wont have a reverse light connection (but a small trailer is unlikely to have one anyway), the other wiring is only really for caravans, to charge the battery and power the fridge etc. so you wont need them. Just an option for you.
You can just push the sensor button on the dash to disable the sensors manually.
Post #361782 12th Dec 2015 12:13am
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Many thanks for all the replies
Conclusion is after guidance on this forum,as my requirement is purely for a bike trailer and so only needing the rear lights then a simple 7 to 13 pin converter will suffice @ £2.99 so am going that route.
When I again buy a caravan I will change the loom properly then get a 13 to 7 converter for the trailer. Many thanks
Paul
Post #361805 12th Dec 2015 10:01am
miggit
Or you could simply change the plug on the trailer to a 7 pin 12n plug Thumbs Up
Assuming that the trailer doesn't have reversing lights.... if it does then the adapter is the way to go at the moment..... although I can see it becoming a requirement that if you've got reversing lights on the trailer they will need to work... not enforced at the moment.... but that will be the next money raiser for the Police Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #361807 12th Dec 2015 10:14am
Pvw10
Thanks for the reply
No reversing lights, its a trials bike trailer so almost skeleton frame, for two bikes, with std lights. Many thanks
Paul
Post #361843 12th Dec 2015 3:43pm
miggit
Think I'd be inclined to leave the car alone and change the trailer plug.... it will be a lot easier to do that the car. In my experience a trailer has more wire available and it is generally more accessible that the wiring on a car Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361850 12th Dec 2015 4:12pm
Zirconblue
That's true, but 13 pin sockets are just far better and more reliable than the old 7 pin ones long term.
Post #361927 12th Dec 2015 9:48pm
Agree - I'd be inclined to just change the socket on the car and leave the 6 connections unused.
Post #361933 12th Dec 2015 10:03pm
Pvw10
We are unanimous that's what will happen 👍 Many thanks
Paul
Post #361938 12th Dec 2015 10:15pm
miggit
Lets hope that there is enough cable, otherwise some one will be cursing you while their face is buried in the bumper and trying to make connections to a socket that you can't see properly Shocked
Plus there is the other consideration, it will make the car a definite failure at MOT time Whistle I believe that the 13 pin socket is part of the MOT test.... how's it going to pass with 7 connections missing? Yesterday I couldn't spell Engineer... Today I are one!
Post #361942 12th Dec 2015 10:26pm
miggit
Look, half way down the page Shocked
http://www.theaa.com/motoring_advice/car-s...-2012.html Yesterday I couldn't spell Engineer... Today I are one!
Post #361945 12th Dec 2015 10:35pm
Good spot Thumbs Up
Post #361946 12th Dec 2015 10:38pm
Pvw10
Yay best stick with 7 pin then Embarassed Many thanks
Paul
Post #361947 12th Dec 2015 10:40pm
miggit
I found that out after I'd fitted the 13 pin socket... another bloody thing to trip me up at MOT time, talk about self inflicted wounds Big Cry Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #361948 12th Dec 2015 10:41pm
Zirconblue
I think if the wires reach a 7 pin they'll reach a 13pin
That's a fair point about the MOT,
(I just checked) MOT manual Section 1.9. They only check the Position lamps, stop lamps, direction indicators and fog lamps. So it would still pass.
https://www.gov.uk/government/uploads/syst...hicles.pdf
The vehicles own reverse lights aren't even checked for the MOT.
Bear in mind though it's only about £70 for a complete Westfalia 13pin wiring kit.
Post #361950 12th Dec 2015 10:44pm
Pvw10
Thinking future proof I'm going this way now.
Get a quality Westy loom and do properly and buy a cheapo 13 to 7 pin converter for the bike trailer, this way I'm covered plus when we buy the Caravan I will be ready.
There decision made, closure wahooooooooooo Many thanks
Paul
Post #361955 12th Dec 2015 11:01pm
Page 2 of 4 <1234>
