Home > Maintenance & Mods (L322) > Hit standing water fast & hard
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi all, as those of you who live in the North west will know we have had another day of rain of biblical proportions. Long story short I hit some 'proper' standing water at speed. I now have a rattle , scraping noise from the front nearside as if I have bent or dislodged some heat protection or similar. Noise can be increased when loading the car on one side when turning and also in time with the cars speed. Anyone know what this is likely to be and where I need to look in the morning ?
Thanks 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #361932 12th Dec 2015 9:59pm
Zirconblue
plastic wheel arch liner rubbing on a tyre i expect.
But this kind of fault is normally pretty obvious once you lay underneath and start bashing stuff with your hand.
Post #361935 12th Dec 2015 10:13pm
RiccartonRR
My money is on the wheel arch liner - possibly grill section at the front of it?
Good luck Thumbs Up Back in a Defender!!
Post #361936 12th Dec 2015 10:14pm
CMJ
Its definitely metal on metal rattle and scrapping ? Does the wheel arch lining have any metal ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #361951 12th Dec 2015 10:45pm
Zirconblue
All plastic i think. Could be a water shield on one of the brake discs.
We can guess all night, once you get under there and start bashing stuff i don't think it will take long for the loose part to let you know. Very Happy
Post #361953 12th Dec 2015 10:49pm
Exhaust heat shield
Post #361964 13th Dec 2015 12:17am
Dolphinboy
None of the above ......
My money is on the brake disc heat shield come loose. Mr. Green
Post #361965 13th Dec 2015 12:24am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Agree with dolphinboy. They crack around the bolt fixing points and break loose. I discarded mine on my Td6. Never noticed any difference and no problem on the MOT. That said they are there for a reason so best to repair if it turns out to be that. Cool
Post #361966 13th Dec 2015 12:39am
holidaychicken
+1
The bolt holes rust out and the bolts pull through, penny washers are the easy fix although I think you can get 2 piece ones now that don't require hub removal to replace them
Post #361967 13th Dec 2015 12:41am
Zirconblue
id already suggested that. Wink
Post #361970 13th Dec 2015 1:04am
holidaychicken
I only read the plastic bit at the beginning of your post Embarassed
Post #361990 13th Dec 2015 10:33am
Dolphinboy
Zircon, you are right but u called it a water shield. Whistle
Thumbs Up Thumbs Up
Post #361991 13th Dec 2015 10:41am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Yes to this, ours did the exact same thing recently, sounded awful when driving the car as well! Backing shield had rusted and the bolts had pulled through the plate.
Post #361993 13th Dec 2015 10:47am
holidaychicken
Permission to laugh if it turns out to be something else ? Very Happy
Post #362027 13th Dec 2015 12:49pm
Zirconblue
Thumbs Up Thumbs Up
They're often referred to as splash guards, grit guards, water shields, heat shields and more often than not, rattly bit of tin on the back of the brake disc. Laughing
In different vehicle manufacturers parts catalogues, they're given all sorts of names.
Post #362050 13th Dec 2015 2:21pm
