![]() | Home > Maintenance & Mods (L322) > Hit standing water fast & hard |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
plastic wheel arch liner rubbing on a tyre i expect.
| RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724
My money is on the wheel arch liner - possibly grill section at the front of it?
| CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208
Its definitely metal on metal rattle and scrapping ? Does the wheel arch lining have any metal ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
All plastic i think. Could be a water shield on one of the brake discs.
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Exhaust heat shield |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
None of the above ......
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Agree with dolphinboy. They crack around the bolt fixing points and break loose. I discarded mine on my Td6. Never noticed any difference and no problem on the MOT. That said they are there for a reason so best to repair if it turns out to be that. |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
+1
id already suggested that. |
I only read the plastic bit at the beginning of your post |
Zircon, you are right but u called it a water shield. |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Yes to this, ours did the exact same thing recently, sounded awful when driving the car as well! Backing shield had rusted and the bolts had pulled through the plate. |
Permission to laugh if it turns out to be something else ? |
They're often referred to as splash guards, grit guards, water shields, heat shields and more often than not, rattly bit of tin on the back of the brake disc. In different vehicle manufacturers parts catalogues, they're given all sorts of names. |
