Home > Technical (L322) > Suspension Problems Please help
xixal
England 2003 Range Rover Vogue Td6 Tonga Green
Just driven to the shops when the "suspension Inactive" warning came on along with the ABS, Brake System and DSC lights. I have checked the codes and its coming up with CAN BUS FAULT, (CURRENT, INTERMITTENT).
I have turned the car off and restarted and it appears ok for a few minutes but when I drive off the warning lights and message appear. The rear suspension seems low but does inflate initially.
Any ideas? I have checked most of the topics but can't find anything that fits the problem
Any help would be greatly appreciated
xixal
Post #36255 15th Nov 2010 7:17pm
it could be the battery on its way out..how old is yours , cos in this cold weather the RR needs a good battery to keep all its ecu's going.... ... - .- -.
Post #36257 15th Nov 2010 7:21pm
xixal
Hi Scarey, just changed the battery 2 months ago, so I'm pretty confident its not that. I have cleared all the codes 3 or 4 times and now it seems to be ok.
I'd love to know what went wrong? Thats if its fixed
Post #36260 15th Nov 2010 8:08pm
when you changed the battery did you check the alternator output..if that was ok then hopefully a more knowledgeable member might help.. ... - .- -.
Post #36261 15th Nov 2010 8:12pm
xixal
I scarey never checked the battry output, don't suppose you know what voltage it should be? xixal
Post #36273 15th Nov 2010 9:06pm
should be 14 to 14.5 volts on idle..... ... - .- -.
Post #36307 16th Nov 2010 9:28am
